Introduction
Use this guide to replace the leaking water inlet valve in a GE top-load washing machine in the GTW220-GTW840 family. Replacing the valve can stop unwanted drips or slow water seepage into the tub. Model details and valve variants may differ slightly, so compare the new part to the original before installation.
Step 1 Disconnect power and water
Turn off the water supply and remove both inlet hoses.
Check for any debris in the inlet filters of the valves and hoses.
Step 2 Prepare for valve removal
Remove the two long 1/4-inch hex-head screws from the back corners of the console.
Lift and rotate the control console forward, taking care of the attached wires and pressure hose.
Disconnect the pressure hose if more room is needed to access the valve area.
Step 3 Remove the old valve
Remove the two short 1/4-inch hex-head screws that secure the water valve to the housing.
Pull each wire harness off the valve solenoids, using needle-nose pliers if the connectors are tight.
Slide the water-valve assembly upward and away from the washer cabinet.
Step 4 Install the new valve
Angle the new water valve into place, then slide it down until it seats.
Shift the tub rearward through the washer lid opening if the valve does not seat properly.
Line up the mounting holes for the valve and reinstall the two shorter screws.
Reconnect each wire harness onto its correct solenoid by matching the original color order.
Step 5 Reattach the console
Reconnect the pressure hose to the control board if you removed it earlier.
Slide the console back and ensure the plastic tabs lock into place over the machine top.
Secure using the two original longer screws at the back of the console.
Step 6 Reconnect water and power
Reconnect the hot and cold supply hoses, and inspect the hose washers for wear.
Open the water valves and plug the washer’s power cord back into the outlet.
Step 7 Check for leaks
Run a quick fill cycle and check for drips around the newly installed valve.
Confirm the wire-harness connections if the washer does not fill properly.
Check the household water pressure if leaks persist after installation.
Step 8 Prevent future valve leaks
Install or replace inline filter screens on the hoses to help keep debris out of the new valve.
Inspect the hoses and screens regularly to avoid buildup that can damage the new valve.
Repair didn't go as planned? Ask our Answers community for help.
