GE TrueTemp Oven Light Bulb Replacement
Views: 21K
View statistics:
Past 24 Hours:
5
Past 7 Days:
37
Past 30 Days:
193
All Time:
20,913
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will give step by step instructions on how to replace the light bulb in an oven, specifically for the GE TrueTemp, however these steps can be used for various other models. This repair only requires a new light bulb and a dry cloth or gloves to protect the bulb from coming into contact with anything that could damage it, including natural oils on the hand. This repair should be fairly quick to complete, as it should take no more than 3-5 minutes. Note that other oven models may have slight variations in the location of the light bulb.
    1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: step 1, image 1 of 1
      • Unplug the power cord from the wall outlet for safety purposes.
      Ask FixBot
    2. GE TrueTemp Oven Light Bulb Replacement: step 2, image 1 of 1
      • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
      Ask FixBot
    3. GE TrueTemp Oven Light Bulb Replacement: step 3, image 1 of 1
      • Locate the metal strap holding the glass cover over the bulb.
      Ask FixBot
    4. GE TrueTemp Oven Light Bulb Replacement: step 4, image 1 of 1
      • Slide the strap to the side to free the glass casing.
      Ask FixBot
    5. GE TrueTemp Oven Light Bulb Replacement: step 5, image 1 of 1
      • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
      • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
      Ask FixBot
    6. GE TrueTemp Oven Light Bulb Replacement: step 6, image 1 of 1
      • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
      Ask FixBot
    7. GE TrueTemp Oven Light Bulb Replacement: step 7, image 1 of 2 GE TrueTemp Oven Light Bulb Replacement: step 7, image 2 of 2
      • Screw in new light bulb in the clock wise direction.
      Ask FixBot
    8. GE TrueTemp Oven Light Bulb Replacement: step 8, image 1 of 1
      • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
      Ask FixBot
    9. GE TrueTemp Oven Light Bulb Replacement: step 9, image 1 of 1
      • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
      Ask FixBot
    10. GE TrueTemp Oven Light Bulb Replacement: step 10, image 1 of 1
      • Plug the oven power cord back into power source.
      Ask FixBot
    11. GE TrueTemp Oven Light Bulb Replacement: step 11, image 1 of 1
      • Press the button for oven light to come on.
      Ask FixBot
    12. GE TrueTemp Oven Light Bulb Replacement: step 12, image 1 of 1
      • View light to ensure the replacement was successful.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 193
All Time: 20,913
