Up to 20% off select tools
GE Refrigerator water filter Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
24
All Time:
36
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide explains how to replace the water filter in a GE GFE24JYKHFFS refrigerator.
The refrigerator's water filter helps remove impurities from drinking water and ice. Over time, the filter can become clogged or less effective, which may cause slower water flow, an unpleasant taste, or a filter replacement alert.
This guide walks you through removing the old filter, installing a compatible replacement, flushing the water system, and resetting the filter indicator.
Before starting, make sure the replacement filter is compatible with your refrigerator model. Keep a towel or container nearby to catch any water that may drip during replacement.
    1. GE Refrigerator water filter Replacement, water filter: step 1, image 1 of 1
      • Look at the refrigerator display. A red filter light may indicate that the water filter needs attention.
      • Check whether the filter-status light indicates that the filter needs attention.
      • A red filter light may indicate that the filter needs attention.
      Ask FixBot
    2. GE Refrigerator water filter Replacement: step 2, image 1 of 1
      • Open the refrigerator door.
      • Locate the filter housing near the upper-right corner inside the refrigerator.
      • Make sure you can reach the housing before removing the old filter.
      Ask FixBot
    3. GE Refrigerator water filter Replacement: step 3, image 1 of 1
      • Open the filter housing.
      • Release the old filter using the method specified in the refrigerator instructions.
      • Remove the filter carefully and catch any drips with a towel.
      • A small amount of water may spill. Do not force the filter if it is difficult to remove.
      Ask FixBot
    4. GE Refrigerator water filter Replacement: step 4, image 1 of 1
      • Read the label on the new filter package.
      • Verify that the filter is compatible with the refrigerator model before opening it.
      • The photographed SS31 package refers to GE XWFE; verify actual compatibility before use.
      Ask FixBot
    5. GE Refrigerator water filter Replacement: step 5, image 1 of 1
      • Remove the new filter from its packaging.
      • Take off any protective wrapping or caps as directed by the filter manufacturer.
      • Keep the filter connector clean while preparing it.
      Ask FixBot
    6. GE Refrigerator water filter Replacement: step 6, image 1 of 1
      • Find the connector end of the new filter.
      • Position the connector so it lines up with the filter housing.
      • Do not force the filter into place.
      Ask FixBot
    7. GE Refrigerator water filter Replacement: step 7, image 1 of 1
      • Insert the replacement filter into the housing.
      • Secure it according to the filter and refrigerator instructions.
      • Close the housing after the filter is locked in place.
      • Check that the filter is fully seated before closing the housing.
      Ask FixBot
    8. GE Refrigerator water filter Replacement: step 8, image 1 of 1
      • Place a large container under the water dispenser.
      • Dispense water to flush the new filter.
      • Follow the flushing amount specified for your actual replacement filter.
      • The photographed package requires 4 gallons; follow the instructions for the filter you install.
      Ask FixBot
    9. GE Refrigerator water filter Replacement: step 9, image 1 of 1
      • Inspect the filter housing and nearby area for leaks
      • Check the refrigerator display to see whether the filter-status indicator needs to be reset.
      • Follow the refrigerator instructions to reset the indicator if necessary.
      • If you notice leaking, stop dispensing water and check the filter installation before continuing.
      Ask FixBot
After installing the new water filter, flush the water system according to the filter manufacturer's instructions. Check for leaks around the filter housing and reset the filter-status indicator if needed.
Your GE refrigerator is now ready to dispense filtered water and make ice with the new filter.
Britney Boromand
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 24
All Time: 36
