Introduction
Go to step 1 ↓Use this guide to replace a cracked or damaged glass stovetop on a GE electric stove. The glass stovetop, also called the cooktop glass or maintop, supports the burners and cookware. Replace it if the glass is cracked, chipped, or no longer sits securely on the frame. This guide was written for GE stove model JBS60DK4BB. Similar models may differ slightly, so confirm the model number before ordering a replacement top.
Step 1 Prepare the stove
Check the model number label in the lower compartment before ordering the replacement glass stovetop.
Let the cooktop cool completely.
Step 2 Lift the glass top
Use a screwdriver to remove the two screws that secure the glass stovetop to the frame.
Lift the front of the glass stovetop so it hinges up from the back.
Support the glass while you work underneath it.
Step 3 Detach the front components
Start at the rear of the cooktop and detach the hot surface light from the underside of the glass.
Release the retaining tabs or clips on one side of a burner.
Slide the other side of the burner out of its mount.
Repeat for every burner still attached to the old glass.
Step 4 Remove the old glass
At the rear of the cooktop, remove any wire retainers attached to the glass.
Use a screwdriver to remove the ground screw from the old glass top.
Lift the old glass stovetop off the hinges once every component is detached.
Step 5 Transfer the retaining clips
Compare the old glass stovetop with the new one before moving any hardware.
Move each retaining clip to the matching location on the new glass.
Set the new glass stovetop onto the rear hinges.
Confirm the new glass sits correctly before reattaching the burners.
Step 6 Reattach the burners
Work from the back toward the front as you reinstall the parts.
Use a screwdriver to reinstall the ground screw and any rear wire retainers.
Slide one side of a burner into its retaining clip.
Align the opposite tab or clip with the matching hole in the new glass.
Press the tab into place until the burner locks in.
Wiggle the burner gently if the tab doesn't drop into the slot.
Step 7 Secure the wires
Reattach all retaining clips that keep the wires out of the way.
Route the wires along their original paths, away from the burner surfaces and glass edges.
Reattach the hot surface light.
Step 8 Close and test the stovetop
Lower the glass stovetop onto the frame while making sure the wires stay clear.
Use a screwdriver to reinstall the two screws that hold the glass stovetop in place.
Plug the stove back in or switch the breaker on.
Test the burners and the hot surface light.
The repair is complete when the glass sits flat, the screws are secure, the wires are retained, and the burners and hot surface light work correctly. Repair didn't go as planned? Ask our Answers community for help.
