GE Front Load Washing Machine Not Draining - Drain Pump Replacement
Video Guide
This guide was transcribed from a YouTube video.
    • Check that the drain hose is not inserted too far into the standpipe.
    • Ensure the drain hose has no kinks or damage that might block water flow.
    • Pull the hose back slightly if it's pushed in too deep to avoid siphoning or backflow.
    Ask FixBot
    • Open the lower access area and remove the pump-filter cover at the bottom front of the washer.
    • Pull the plastic tray down to reveal the blue release knob on the pump filter.
    • Place a towel or tray underneath and slowly turn the knob counterclockwise to release water.
    • Use the knob to control the water flow until it fully drains from the pump housing.
    • Remove and inspect the filter for debris or obstructions and clean it thoroughly.
    Ask FixBot
    • Pull the dispenser drawer all the way out and press the rear tab to release it.
    • Remove the five screws in the dispenser housing with a suitable screwdriver.
    • A magnetic screwdriver helps if screws fall inside the housing.
    • Lift the left side of the console and push it right to free it from the washer.
    Ask FixBot
    • Remove the three small screws along the top of the washer behind the console area.
    • Slide the panel forward and lift it up to access the top of the machine.
    • Detach or reposition the short wire harness if needed to gain more access.
    Ask FixBot
    • Release the outer door-boot spring with a flat tool, then peel the boot away from the front panel.
    • Watch for sharp metal edges as you pull the gasket from the washer opening.
    • Remove the two screws holding the plastic door-lock trim on the right side.
    • Remove the additional two screws securing the door lock and lift its tab free.
    Ask FixBot
    • Remove the nine screws around the bulkhead, including the screw near the dispenser area.
    • Tilt the washer carefully if you must remove three bottom screws, using a stable support.
    • Slide the air baffle free by releasing its retention tabs after removing the middle screws.
    • Lift the bulkhead up and pull it forward slightly to separate it from the washer frame.
    • Unplug the door wire harness on the left side to remove the bulkhead completely.
    Ask FixBot
    • Make sure the washer is fully drained through the pump filter before removing the pump.
    • Use slip joint pliers to compress and slide the hose clamps back, then remove each hose.
    • Expect some residual water and place a towel underneath to contain spills.
    • Remove the two top screws securing the pump assembly with a short screwdriver.
    • Disconnect the wire harness on the pump before maneuvering the unit out of the machine.
    Ask FixBot
    • Check the rubber hoses for blockages before installing the replacement pump.
    • Reconnect the wiring to the new pump first while you have more space to maneuver.
    • Align the pump with the rubber grommets and press it forward to position the screw holes.
    • Secure the pump with the two screws, feeling for the threaded openings if working blind.
    • Reattach both hoses, ensuring the black hose notch is oriented correctly, then clamp them.
    Ask FixBot
    • Reconnect the left-side wire harness behind the bulkhead before reinstalling it.
    • Lift the bulkhead above the washer chassis and lower it onto its plastic mounts.
    • Reinsert the bulkhead screws, beginning at the outer edges and moving toward the center.
    • Guide the door boot fan assembly into its slots and secure it with the related screws.
    • Reattach the door lock properly, adding two screws, then replace the plastic facade.
    Ask FixBot
    • Press the door boot gasket back onto the metal lip around the front opening.
    • Stretch the door boot spring back into place using a door boot spring tool or zip ties if needed.
    • Slide the washer's top panel into position and secure it with the three mounting screws.
    • Hook the console onto the two large screws on the right and push left to lock it.
    • Hold the dispenser housing firmly while installing the five screws, with the two larger in the middle.
    • Insert the dispenser drawer fully and ensure it latches securely in place.
    Ask FixBot
    • Run a drain or spin cycle to confirm the washer now drains and spins properly.
    • Check diagnostic codes or measure control board output voltage if the issue persists.
    Ask FixBot
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,100 Reputation
224 Guides authored
1 Guide Comment
It looks like you can do what you've posted without having to take off the top panel of the machine- My machine is stacked with the dryer above. Could the machine be taken apart and drain pump replaced without removing the top panel- i.e., not having to unstack the machines? Thank you!
Sara Levine Kornfield - Reply Share
Past 24 Hours: 20
Past 7 Days: 175
Past 30 Days: 684
All Time: 7,154
