GE Electric Dryer Mica Heating Element Replacement
Video Guide
This guide was transcribed from a YouTube video.
    • Unplug the dryer from its power source and slide the cabinet forward so the back panel is accessible.
    • Wear cut-resistant gloves and long sleeves before touching the chassis because GE dryers contain many sharp edges.
    Ask FixBot
    • Remove the two ¼-inch hex screws located at the lower corners of the rear panel.
    • Strike both console ends with the palm to push the console rearward until its front tabs release.
    Ask FixBot
    • Lift the loosened console upward to rest on top of the cabinet.
    • Remove the two Phillips screws at the upper rear corners of the console housing.
    • Re-insert the console tabs into the lid slots and press down so the lid remains attached for later hinging.
    Ask FixBot
    • Open the dryer door and locate the two Phillips screws hidden under the front lip of the lid opening.
    • Remove both screws and gently swing the lid back toward the wall, using the console as a rest.
    Ask FixBot
    • Remove the quarter-inch hex screw on each side of the front panel near the top corners.
    • Keep your gloved fingers clear of the razor-sharp side panels while loosening these screws.
    Ask FixBot
    • Detach the drum-light harness from the left top corner of the front panel if your model is equipped with it.
    Ask FixBot
    • Tilt the front panel forward and support it so the short door-switch harness is visible.
    • Slide the plastic shield aside, press the latch and unplug the door-switch connector.
    • Lift the panel straight up to clear the three lower locating fingers and move it away from the dryer.
    • Do not yank the harness; its limited length can break the switch or bend the connector pins.
    Ask FixBot
    • Reach through the front opening and pull the idler pulley to the right to slacken the belt.
    • Rest the pulley bracket on the small metal tab of the motor mount to hold tension clear.
    • Slide the belt off the motor shaft and idler pulley.
    Ask FixBot
    • Lift the drum slightly by the belt, pull it forward and remove it from the cabinet.
    • Watch for the belt catching on the motor pulley and free it if necessary to avoid bending the belt.
    Ask FixBot
    • Unplug the two sensor wires on the upper left of the heater pan.
    • Unplug the sensor wire on the upper right of the pan.
    • Remove the purple supply wire and the two blue element wires from the heater terminals.
    • Use needle-nose pliers or a flat blade screwdriver to pry the terminals straight off without twisting.
    Ask FixBot
    • Remove the four ¼-inch hex screws holding the heater pan to the cabinet.
    • Hold the pan with one hand while removing the final screw so it does not drop and cut the wiring.
    • Pull the pan completely out and place it on a flat work surface.
    Ask FixBot
    • Bend the locking tab away from the mica heater using pliers or a flat blade screwdriver.
    • Rotate the old heater counter-clockwise until its tabs clear the slots in the pan.
    • Lift the heater out, working around any warped tabs until it is free.
    Ask FixBot
    • Place the new aftermarket mica heater element into the lower slots of the pan, keeping the terminals oriented like the original.
    • Press the heater evenly so it sits flush all around the rim.
    • Rotate the heater clockwise until every tab locks under the pan edges.
    • Ensure no heater wires protrude; bending them can cause shorts and premature failure.
    Ask FixBot
    • Re-bend the locking tab tightly over the new heater rim to secure the assembly.
    Ask FixBot
    • Hold the heater pan against the cabinet and install one mounting screw by hand.
    • Install the screw opposite the first, then add the remaining two to fully secure the pan.
    • Reconnect the three sensor wires and the three element wires to their original terminals.
    • Tug each connector lightly to verify a firm fit; loose connections cause no-heat callbacks.
    Ask FixBot
    • Pre-load the idler pulley onto the motor tab to make belt routing easier.
    • Position the drum in the cabinet, guiding the rear bearing straight into its socket.
    • Verify the belt sits in the rear groove that shows the old belt mark.
    • Route the belt around the motor shaft, then release the idler pulley to tension it.
    Ask FixBot
    • Spin the drum by hand to confirm the belt moves the blower wheel smoothly without snagging.
    Ask FixBot
    • Set the front panel back onto the three locating fingers at the bottom of the cabinet.
    • Reconnect the door-switch harness and slide the plastic cover back over the connector.
    • Pivot the panel upright, making sure the drum bearing seats into the felt on the door frame.
    • Align the small side tabs on the panel with the chassis slots to prevent misalignment.
    Ask FixBot
    • Install the two ¼-inch hex screws at the top corners of the front panel.
    • If your model has a drum-light harness, reattach it above the left side screw.
    • Lower the lid and install the two Phillips screws removed from the door opening earlier.
    • Push the lid forward until it snaps onto the chassis.
    Ask FixBot
    • Plug the dryer back in and run a timed-heat cycle to verify that the element glows and air temperature rises steadily.
    • If the unit still does not heat, re-check all wire connections before investigating thermostats or breakers.
    Ask FixBot
    • Remove power again, then reinstall the two rear Phillips screws that secure the console housing.
    • Pivot the console forward and tap its rear edge to lock the six fingers into the lid slots.
    • Reinstall the two ¼-inch hex screws at the bottom rear corners of the cabinet.
    • Restore power; the dryer is now ready for normal use at roughly half the cost of replacing the full heater pan.
    Ask FixBot
Replacing only the mica heating element restores full heat while saving significant money over a complete heater-pan assembly. Keep the gloves handy for any future servicing, and double-check wire connections anytime the dryer loses heat.
Ben Schlichter
6,542 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 37
All Time: 157
