Video Guide
This guide was transcribed from a YouTube video.
Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace the user interface on a GE dishwasher model GDT545PSJ5SS. The user interface, also called the button panel or control panel, lets you choose cycles and send commands to the control board. Replace it if the panel stays dark, the buttons don't respond, and testing shows the control board is still sending power to the interface. Other GE dishwasher models may use a similar assembly, but the jumper settings, wiring, and screw locations can differ.
Step 1 Disconnect power and open the lower access area
Use a screwdriver to remove the two screws securing the kick plate.
Set the kick plate and the strip of noise dampening foam aside.
Use a voltage detector to confirm the dishwasher power is off.
Remove the screw securing the junction box cover, and set the cover aside.
Step 2 Lower the control board tray
Use a screwdriver to remove the two screws securing the metal control board tray.
Lower the tray enough to access the control board and its connectors.
Step 3 Test control board output
Set a multimeter to measure DC volts.
Locate the row of five pins on the control board.
Place one multimeter probe on pin 5 and the other probe on pin 2.
Step 4 Interpret the test result
If the board LED is on and the pin test reads about 14 volts DC, the user interface is the likely failed part.
Raise the control board tray back into place.
Use a screwdriver to reinstall the two screws securing the control board tray.
Step 5 Disconnect the user interface harness
Disconnect the wiring plug that runs from the control board to the user interface.
Use a socket wrench to remove the two screws holding the door to the hinges.
Look under each hinge area for the two small hinge-lock holes.
Step 6 Lock the hinges open
Insert an Allen wrench into the hinge-lock hole on one side.
Open the door until the hinge holes line up and the Allen wrench holds the hinge open.
Repeat the same process on the other hinge.
Step 7 Remove the door
Rock the door back and forth gently to work it free from the hinges.
Use snips to cut the zip ties holding the door wiring.
Lift the door away from the dishwasher.
Step 8 Separate the door halves
Use a screwdriver to remove the two screws that join the door halves.
Remove the small vent cover from the door.
Press down on the handle while lifting the inner half of the door.
Separate the plastic outer door piece from the metal inner door piece.
Step 9 Remove the user interface assembly
Disconnect the cable that comes from the control board to the user interface.
Use a screwdriver to remove the four screws securing the user interface assembly.
Slide the user interface assembly out of the top of the door.
Step 10 Remove the old user interface board
Use a small Phillips screwdriver to release the plastic clips around the user interface housing.
Pry the two housing halves apart as each clip releases.
Lift the old user interface board out of the plastic housing.
Step 11 Configure the new user interface
Use the personality configuration sheet that comes with the new user interface.
Find the dishwasher model number on the sheet and match it to the correct jumper positions.
Set jumpers 8, 4, and 2 to closed, and set jumper 1 to open for a GDT545 configuration.
Step 12 Reinstall the user interface assembly
Place the new user interface board into the plastic housing.
Set the button piece back onto the housing.
Press the housing together until all the clips snap into place.
Slide the user interface assembly back into the top of the door.
Use a screwdriver to reinstall the two long screws in the center holes.
Use a screwdriver to reinstall the two shorter screws in the outer holes.
Reconnect the wiring to the user interface.
Step 13 Reassemble the door
Align the teeth on the plastic door piece with the grooves in the metal door piece.
Slide the plastic door piece down into place.
Use a screwdriver to reinstall the two screws holding the door halves together.
Reinstall the vent cover and tighten its screw.
Step 14 Reinstall the door on the hinges
Work the door back onto the hinges, adjusting the angle until it seats correctly.
Remove the Allen wrenches from both hinge-lock holes after the door is seated.
Reconnect the user interface wiring to the control board.
Step 15 Test the repair
Turn the breaker on and confirm the user interface lights up.
Press the buttons and make sure the dishwasher responds.
Step 16 Secure the lower hardware
Use a socket wrench to reinstall the two screws that secure the door to the hinges.
Reinstall the junction box cover and tighten its screw.
Reinstall the noise-dampening foam strip.
Reinstall the kick plate.
Use a screwdriver to reinstall the two kick plate screws.
Turn the breaker back on after all covers and screws are in place.
Step 17 Run a test cycle
Start a dishwasher cycle and confirm the dishwasher fills, washes, and responds to the controls.
The user interface is replaced once the panel lights up, the buttons respond correctly, and the dishwasher completes normal cycles. Repair didn't go as planned? Ask our Answers community for help.
