Video Guide
This guide was transcribed from a YouTube video.
Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace the control board in a GE dishwasher model GDT545PSJ5SS that has no power, no lights, and no response from the Select Cycle or Start buttons. The control board, also called the electronic control board or main control board, manages dishwasher power and controls. This guide was written around control board part WD21X24901, but similar GE dishwashers may have small layout differences.
Step 1 Reset the breaker
Find the dishwasher breaker in the electrical panel.
Switch the breaker off, wait a few seconds, then switch it back on to reset the dishwasher.
Check whether the controls light up and respond to the Select Cycle and Start buttons.
If the dishwasher is still dead, turn the breaker back off and leave it off for the repair.
Step 2 Remove the kick plate
Confirm that the dishwasher breaker is off before working underneath the machine.
Remove the two screws securing the kick plate with a Phillips screwdriver.
Pull the kick plate away from the dishwasher.
Remove the strip of noise-dampening foam if it is installed behind the kick plate.
Use a non-contact voltage detector near the wiring in the toe-kick area.
Step 3 Disconnect the power connector
Remove the screw securing the small junction-box cover with a Phillips screwdriver.
Pull off the junction-box cover.
Press the clip on the dishwasher power connector.
Pull the connector down to disconnect power from the dishwasher.
Step 4 Move the junction box bracket
Remove the two screws securing the junction-box bracket to the frame with a Phillips screwdriver.
Push the bracket back and out of the way.
Disconnect the cable that runs to the front panel.
Step 5 Lower the control board tray
Locate the two front screws with black rubber washers.
Remove the two screws with a Phillips screwdriver.
Support the tray while removing the second screw so it does not drop.
Lower the tray enough to see how the wires are routed.
Step 6 Disconnect the board connectors
Locate the three connectors plugged into the control board.
Press the retaining clip on each connector.
Pull each connector straight out of the board.
Slide the tray out from under the dishwasher after all three connectors are free.
Step 7 Remove the old control board
Remove the screw securing the control board to the tray with a Phillips screwdriver.
Press the tabs on the plastic mounting posts inward with the tip of a screwdriver.
Lift the control board off the mounting posts.
Step 8 Prepare the replacement board
Compare the old and new boards to make sure the connectors and mounting points match.
Step 9 Install the replacement board
Align the replacement board over the plastic mounting posts on the tray.
Press the board down until the plastic tabs hold it in place.
Reinstall the control-board screw.
Step 10 Reconnect the board cables
Slide the metal tray back under the dishwasher.
Reconnect all three plugs to the control board.
Press each plug in until its clip seats.
Step 11 Seat the control board tray
Lay the wires back into the channels in the metal tray and dishwasher frame.
Lift the tray into place while keeping the wires aligned in the grooves.
Reinstall the two front screws with black rubber washers using a Phillips screwdriver.
Step 12 Reconnect the front panel and bracket
Reconnect the cable for the front panel.
Pull the junction-box bracket back to the frame.
Reinstall the two bracket screws with a Phillips screwdriver.
Plug the dishwasher power connector back in until the clip seats.
Step 13 Close the junction box
Slide the junction-box cover back into place.
Guide the wires into the box if they block the cover.
Reinstall the junction-box cover screw with a Phillips screwdriver.
Step 14 Reinstall the kick plate
Reinstall the noise-dampening foam if you removed it.
Position the kick plate at the bottom of the dishwasher.
Reinstall the two kick-plate screws with a Phillips screwdriver.
Step 15 Restore power and test
Turn the dishwasher breaker back on at the electrical panel.
Confirm that the control lights come on and the Select Cycle and Start buttons respond.
Run a test cycle and listen for normal dishwasher operation.
Run a test cycle before returning the dishwasher to normal use. Repair didn't go as planned? Ask our Answers community for help.
