Introduction
If the door on your GE combo washer dryer won’t lock, the machine may show a door-related error, report the door as open when it’s shut, or refuse to start. This guide shows how to diagnose door lock problems and replace the door lock (also called the door latch or door interlock), including inspecting the striker, checking the harness, testing the lock with a multimeter, and reinstalling the front panel and gasket.
This procedure documents a GE Ultrafast 2-in-1 combo unit, but other GE combo models may have minor differences in screw locations, wiring routing, and trim.
Step 1 Identify door lock related symptoms and codes
Look for door lock symptoms like a red or yellow error on the front panel, or a message that the door is open when it’s fully closed.
Check the machine’s diagnostic codes and write down any codes related to the door lock system before disassembling anything.
Step 2 Inspect the striker and lock opening
Open the door and inspect the door striker for cracks, missing pieces, or obvious damage.
Wiggle the striker and confirm it can move slightly as needed, even when the screws are tight.
Make sure the striker area is clear and nothing blocks it from entering the lock.
Inspect the door lock opening on the washer and clear any obstructions from the locking mechanism.
Press the small round button on the lock opening and confirm it’s intact and moves freely.
Step 3 Gather tools and set up screw organization
Gather a Phillips head screwdriver, pliers, a multimeter, and a small flat bladed screwdriver.
Plan a way to reinstall the door boot retaining spring, such as a door boot spring tool or a wrench and cable ties.
Step 4 Disconnect power and remove the dispensers
Pull the detergent and fabric softener dispensers fully out until they stop.
Press the rear tab on each dispenser, and pull the dispenser out of the machine.
Step 5 Remove the interface screws and filter housing
Use a Phillips head screwdriver to remove the five deep screws behind the dispenser area.
Pull the filter out as far as it’ll go.
Press the tab on the left side of the filter, and pull the entire filter housing assembly out.
Step 6 Remove the console and disconnect the harnesses
Pull the console forward from the front-left corner, lift it up, and detach it from the front of the machine.
Disconnect the four black-highlighted harness connections needed to separate the interface from the machine.
Disconnect the door light harness by pressing in the clip and pulling the connector apart.
Lift the console away once the wiring is free.
Step 7 Remove the gasket retainer and expose the door lock
Open the door.
Use a small flat bladed screwdriver to find and pry out the retainer wire hiding behind the folds of the door gasket.
Carefully remove the retainer wire from around the gasket.
Peel the gasket edge off the front lip of the washer near the door lock area.
Step 8 Remove the door lock and check the harness
Use a Phillips head screwdriver to remove the two screws from the plastic door lock cover, and pull the cover off.
Use a Phillips head screwdriver to remove the two screws holding the door lock to the washer front.
Reach through the gasket opening, lift the door lock up, and remove it from its housing.
Inspect the door lock harness connection for a dislodged connector or damaged wiring.
Press the small plastic locking mechanism piece on the lock to confirm it isn’t stuck.
Step 9 Remove the front panel for more working room
Use a Phillips head screwdriver to remove the three screws from the bottom of the washer front.
Use pliers to slide the dispenser hose clamp back, and remove the tube.
Use a Phillips head screwdriver to remove the six screws along the top of the washer front, noting the far-right screw is wider and different.
Lift the washer front up, and pull it away from the machine to remove it.
Step 10 Test the door lock with a multimeter
Set a multimeter to ohms resistance.
Test the lock terminals with the door striker not inserted, and confirm the meter shows OL on any prong combination.
Insert the door striker and confirm you still don’t get a reading between pin one and pin two, or pin two and pin three.
Press the door lock button and check for about 118 to 127 ohms between pins two and three.
With the lock in the locked state, depress the button and check for roughly 125 ohms (give or take about 10 ohms) between pins one and two, and between pins two and three.
Step 11 Install the replacement door lock on the harness
Plug the harness into the replacement door lock.
Step 12 Reinstall the front panel
Align the washer front with the plastic pegs on the chassis, lift it up, rest it on the pegs, and slide it down into place.
Confirm there’s no notable gap between the washer front and the chassis sides, and check that the bottom seats near the three metal fingers.
Reinstall the six top screws, putting the large wide-headed screw back in the far-right position.
Step 13 Reconnect the dispenser hose and seat the door lock
Reach in and seat the door lock into the washer front, making sure the small plastic catch rests on the metal of the door opening.
Push the rubber hose onto the barb, and use needle nose pliers to move the hose clamp back into position.
Step 14 Reinstall the gasket and retaining spring
Work the door gasket back onto the chassis, seating all folds behind the metal lip around the opening.
Reinstall the door gasket retaining spring, using a method that can handle the small spring size on this model.
Step 15 Secure the door lock and reinstall the console
Use a Phillips head screwdriver to install the larger, thicker, finer-thread screws into the door lock plate.
Reconnect the harnesses at the interface, including the NTC wire, the dispenser wire, the door light wire, and the main control power wire.
Reinsert the blower thermistor assembly or its wire, depending on how much you removed earlier.
Roll the interface panel up into the heat shield, thread it onto the two large wide screws on the right, and lock it into place.
Slide both dispensers back in, aligning the groove on the smaller lower dispenser with the housing so it seats properly.
Step 16 Test operation and troubleshoot if the problem remains
Plug the machine back in and test the door lock operation.
If the issue continues, recheck the door lock harness routing and connectors for anything loose, pinched, or disconnected.
If the door lock and harness check out, inspect for a disconnected wire at the main board.
Repair didn't go as planned? Ask our Answers community for help.
