GE 29875GE1 Speaker Replacement
    1. GE 29875GE1 Speaker Replacement, Remove the Screws on Outer Back Casing.: step 1, image 1 of 2 GE 29875GE1 Speaker Replacement, Remove the Screws on Outer Back Casing.: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the 4 small foam piece on the back casing of the device using a metal tweezers. After remove the 4 screws under the foam piece using a Phillips screwdriver (#size)
      Ask FixBot
    2. GE 29875GE1 Speaker Replacement, Separate the front from the back case.: step 2, image 1 of 1
      • Carefully separate the device's front outer casing from the back outer casing.
      • The device’s front and back outer casing might be hard to separate sometimes. To separate them without damaging other parts use a plastic opening tool to separate the front and back casing.
      • Be careful not to damage the cable on the speaker and microphone while pulling the back outer casing away from the front casing.
      Ask FixBot
    3. GE 29875GE1 Speaker Replacement, Pull the Microphone Piece Out.: step 3, image 1 of 1
      • The microphone will still be on the front casing while connected on the main board on the back casing. Softly using your finger pull the microphone out of the casing.
      • The speaker cable will be connected on the back casing, while glued on the front casing, so carefully put them next to each other so you won't cut the wires.
      Ask FixBot
    4. GE 29875GE1 Speaker Replacement, Remove Speaker From the Casing.: step 4, image 1 of 1
      • The speaker will be glued to the front casing. To remove the glue use a metal spudger or use a heat gun to head the glue and remove the speaker.
      • Be Careful while using the metal spudger, so you won't damage the speaker housing.
      Ask FixBot
    5. GE 29875GE1 Speaker Replacement, Main Board Removal.: step 5, image 1 of 1
      • Remove the 3 screw that holds the main board to the back casing using Phillips head #2 screwdriver.
      • After lift the main board from the back outer casing using a plastic opener tool.
      Ask FixBot
    6. GE 29875GE1 Speaker Replacement, Wire and Soldering.: step 6, image 1 of 1
      • The Speaker is connected of the main board of the device with two color coded wires.
      • Before Taking apart the speaker you must take out the soldering wire on back of the main board. After removing it you can install the new speakers.
      • information sign - The red wire is positive and the black wire is negative they must be soldered in the same position they were on the old speakers.
      Ask FixBot
Antonio Monteiro
119 Reputation
1 Guide authored
UMass Dartmouth, Team 4-6, Miles Fall 2014 Member of UMass Dartmouth, Team 4-6, Miles Fall 2014
UMASSD-MILES-F14S4G6
3 Members
27 Guides authored
1 Guide Comment
Wonderfully illustrated and explained procedure. Thank you. I will try it. I am having trouble with the buttons. I now have to press them several times from different angles before they work. I wonder if the contacts are dirty and if a spray of electronic cleaning fluid will work? I will let you know, Bill
William Fuhrmann - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 809
