GD Midea FT30-3D Power/Speed Switch Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
95
All Time:
4,533
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. GD Midea FT30-3D Power/Speed Switch Replacement, Bottom Base: step 1, image 1 of 1
      • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
      Ask FixBot
    2. GD Midea FT30-3D Power/Speed Switch Replacement: step 2, image 1 of 2 GD Midea FT30-3D Power/Speed Switch Replacement: step 2, image 2 of 2
      • Locate the gray base support release tabs found on either side pictured in the first image.
      • There are release tabs on each side of the base.
      • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
      Ask FixBot
    3. GD Midea FT30-3D Power/Speed Switch Replacement: step 3, image 1 of 1
      • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
      • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
      Ask FixBot
    4. GD Midea FT30-3D Power/Speed Switch Replacement: step 4, image 1 of 1
      • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
      Ask FixBot
    5. GD Midea FT30-3D Power/Speed Switch Replacement: step 5, image 1 of 1
      • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
      • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
      Ask FixBot
    6. GD Midea FT30-3D Power/Speed Switch Replacement: step 6, image 1 of 1
      • Once all five screws have been removed the base cover should fall right off with out any effort.
      • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
      Ask FixBot
    1. GD Midea FT30-3D Power/Speed Switch Replacement, Power/Speed Switch: step 7, image 1 of 1
      • Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
      • Notice the AC power cord line (white wire) goes into the switch under the [Off] button
      Ask FixBot
    2. GD Midea FT30-3D Power/Speed Switch Replacement: step 8, image 1 of 1
      • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
      • The wires should release with ease if done properly.
      • When reassembling; skip this step.
      Ask FixBot
    3. GD Midea FT30-3D Power/Speed Switch Replacement: step 9, image 1 of 1
      • Take the new switch, and simply push the wiring into the correct holes:
      • AC Power Cord (white wire)
      • Low speed (gray wire)
      • Medium speed (orange wire)
      • High speed (red wire)
      Ask FixBot
2 other people completed this guide.
Alan Su
846 Reputation
6 Guides authored
Cal Poly, Team 24-28, Regan Fall 2012 Member of Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 95
All Time: 4,533
