GD Midea FT30-3D Motor Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
104
All Time:
8,644
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This installation guide will demonstrate how to remove all of the components around the main fan blade motor.
Tools
    1. GD Midea FT30-3D Motor Replacement, Fan Blades: step 1, image 1 of 2 GD Midea FT30-3D Motor Replacement, Fan Blades: step 1, image 2 of 2
      • Release the 3 clips that attach the front fan guard to the rear fan guard.
      • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
      Ask FixBot
    2. GD Midea FT30-3D Motor Replacement: step 2, image 1 of 1
      • Pull the front fan guard off.
      Ask FixBot
    3. GD Midea FT30-3D Motor Replacement: step 3, image 1 of 2 GD Midea FT30-3D Motor Replacement: step 3, image 2 of 2
      • Remove the spinner from the center of the fan blade.
      Ask FixBot
    4. GD Midea FT30-3D Motor Replacement: step 4, image 1 of 1
      • The fan blades should now be easy to lift up.
      • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
      Ask FixBot
    1. GD Midea FT30-3D Motor Replacement, Oscillation Mechanism: step 5, image 1 of 1
      • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
      • The plastic nut needs to be twisted off; like a screw.
      Ask FixBot
    2. GD Midea FT30-3D Motor Replacement: step 6, image 1 of 2 GD Midea FT30-3D Motor Replacement: step 6, image 2 of 2
      • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
      • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
      Ask FixBot
    3. GD Midea FT30-3D Motor Replacement: step 7, image 1 of 1
      • Remove the front motor housing by removing 4 screws.
      Ask FixBot
    4. GD Midea FT30-3D Motor Replacement: step 8, image 1 of 2 GD Midea FT30-3D Motor Replacement: step 8, image 2 of 2
      • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
      Ask FixBot
    5. GD Midea FT30-3D Motor Replacement: step 9, image 1 of 1
      • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
      Ask FixBot
    6. GD Midea FT30-3D Motor Replacement: step 10, image 1 of 2 GD Midea FT30-3D Motor Replacement: step 10, image 2 of 2
      • Remove the screw that connects the oscillator to the rocker arm.
      • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
      Ask FixBot
    7. GD Midea FT30-3D Motor Replacement: step 11, image 1 of 1
      • The oscillator should now be easy to pull off.
      • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
      Ask FixBot
    1. GD Midea FT30-3D Motor Replacement, Motor: step 12, image 1 of 2 GD Midea FT30-3D Motor Replacement, Motor: step 12, image 2 of 2
      • At the base of the upper assembly there is a plug which conceals a screw.
      • The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
      Ask FixBot
    2. GD Midea FT30-3D Motor Replacement: step 13, image 1 of 1
      • Slide the motor out of the base of the upper assembly.
      Ask FixBot
10 other people completed this guide.
Alan Su
846 Reputation
6 Guides authored
Cal Poly, Team 24-28, Regan Fall 2012 Member of Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Members
120 Guides authored
4 Guide Comments
Alan Su (y contribuidores): Excelente aporte!!! Felicidades me ha sido muy útil. Gracias
Oliver K - Reply Share
Hey. Could you tell me where to buy the spare motor from please?
Hywel Williams - Reply Share
where can i buy the motor?
HAL SCHEDLER - Reply Share
Where can I buy the motor???
anonymous 2683 - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 104
All Time: 8,644
