Up to 20% off select tools
GATEWAY NE56R09u RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
61
All Time:
721
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
The purpose of the RAM are for quick and temporary memory slots, this model specifically has two RAM that are blue in color. Before attempting to do a replacement, make sure your device is powered off and make sure to read through the guide first before jumping straight into a repair. Safety is always first!
    1. GATEWAY NE56R09u RAM Replacement, Battery: step 1, image 1 of 1
      • Before you begin, make sure the laptop is turned off.
      • Flip your laptop over so the bottom is facing up.
      Ask FixBot
    2. GATEWAY NE56R09u RAM Replacement: step 2, image 1 of 1
      • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
      Ask FixBot
    3. GATEWAY NE56R09u RAM Replacement: step 3, image 1 of 1
      • Lift the battery from the back casing to remove it.
      Ask FixBot
    1. GATEWAY NE56R09u RAM Replacement, RAM: step 4, image 1 of 1
      • Locate the casing that protects the RAM modules, wireless card, and hard drive.
      Ask FixBot
    2. GATEWAY NE56R09u RAM Replacement: step 5, image 1 of 1
      • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
      Ask FixBot
    3. GATEWAY NE56R09u RAM Replacement: step 6, image 1 of 1
      • On each RAM module there are two silver latches holding them in place
      • Release the latches to be able to remove the RAM module.
      Ask FixBot
    4. GATEWAY NE56R09u RAM Replacement: step 7, image 1 of 1
      • Remove the RAM modules from their respected slots.
      Ask FixBot
To reassemble your device, please follow these instructions in reverse order.
Author
with
joshua depina
401 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 61
All Time: 721
