GATEWAY ML6720 Hard Drive Replacement
    1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Flip the laptop on to its backside.
      Ask FixBot
    2. GATEWAY ML6720 Hard Drive Replacement: step 2, image 1 of 1
      • Locate the hard drive at the bottom left corner of the laptop's backside.
      Ask FixBot
    3. GATEWAY ML6720 Hard Drive Replacement: step 3, image 1 of 2 GATEWAY ML6720 Hard Drive Replacement: step 3, image 2 of 2
      • Insert the correct screwdriver mentioned in this guide.
      • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
      Ask FixBot
    4. GATEWAY ML6720 Hard Drive Replacement: step 4, image 1 of 1
      • Slide the hard drive's cover plate out to the left and take it off.
      Ask FixBot
    5. GATEWAY ML6720 Hard Drive Replacement: step 5, image 1 of 1
      • Pop the hard drive out of the compartment.
      Ask FixBot
Nathan Da Silva
431 Reputation
4 Guides authored
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 98
All Time: 770
