Up to 20% off select tools
GARDENA Smart Gateway Repair
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
92
All Time:
2,103
Comments: 7
7 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
If the GARDENA smart Gateway can no longer be powered on there may be various reasons which are easy to fix. This guide refers to the fuses installed in the device.
    1. GARDENA Smart Gateway Repair, Open device: step 1, image 1 of 2 GARDENA Smart Gateway Repair, Open device: step 1, image 2 of 2
      • Remove the rubber feet. Below are four Torx T9 screws.
      Ask FixBot
    2. GARDENA Smart Gateway Repair, Fuse: step 2, image 1 of 1
      • Identify if the fuse is blown. Take a multimeter and measure the resistance. There should be no measurable resistance.
      • If the fuse is defective it should be replaced with a new one. Component listed under parts.
      Ask FixBot
    3. GARDENA Smart Gateway Repair, TVS Diode: step 3, image 1 of 1
      • Second component likely to fail is the TVS Diode (Transient-voltage-suppression diode). It is used to protect the sensitive circuit from overvoltage.
      • Measure the resistance on the two terminals. Resistance should be infinite.
      • If component is broken the circuit is shorted. Therefore the component can be removed in order to repair the device. Afterwards the circuit is not protected against overvoltage anymore!
      Ask FixBot
    4. GARDENA Smart Gateway Repair, Test the device: step 4, image 1 of 1
      • Power LED should light up green
      Ask FixBot
Author
with
Computerix
910 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 92
All Time: 2,103
