G&G CM RK47 Airsoft Disassembly
Views: 8.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
46
Past 30 Days:
149
All Time:
8,398
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The G&G CM RK47 is one of the most affordable and reliable AEG's on the market and with this guide it is easy to dissemble as well.
    1. G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: step 1, image 1 of 3 G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: step 1, image 2 of 3 G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: step 1, image 3 of 3
      • Start by pressing the top cover retainer button and lifting the top cover off of the gun.
      Ask FixBot
    2. G&G CM RK47 Airsoft Disassembly: step 2, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 2, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 2, image 3 of 3
      • Pull the thin black rod away from the top cover button and swing it outwards.
      • Remove the small screw from the plastic receiver cover using a #0 Phillips screwdriver.
      Ask FixBot
    3. G&G CM RK47 Airsoft Disassembly: step 3, image 1 of 2 G&G CM RK47 Airsoft Disassembly: step 3, image 2 of 2
      • Lift the plastic receiver cover from the receiver and remove it.
      • Slide the top cover retainer button out of its groove and remove it.
      Ask FixBot
    4. G&G CM RK47 Airsoft Disassembly: step 4, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 4, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 4, image 3 of 3
      • Remove the four screws on the underside of the receiver with a 2mm hex driver.
      • Pull the barrel assembly out of the receiver.
      • Remove the two screws holding the hop-up unit in place.
      • Pull the inner barrel out of the outer barrel.
      Ask FixBot
    5. G&G CM RK47 Airsoft Disassembly: step 5, image 1 of 2 G&G CM RK47 Airsoft Disassembly: step 5, image 2 of 2
      • Remove the screw a the bottom of the pistol grip with a #2 Phillips screwdriver.
      • Remove the two motor mount screws with a 2mm hex driver.
      Ask FixBot
    6. G&G CM RK47 Airsoft Disassembly: step 6, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 6, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 6, image 3 of 3
      • Using a flat head screwdriver, pry off the selector lever cap.
      • Once the cap is removed, remove the screw underneath with a #2 Phillips screwdriver.
      • Remove the selector lever.
      Ask FixBot
    7. G&G CM RK47 Airsoft Disassembly: step 7, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 7, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 7, image 3 of 3
      • Carefully remove the gearbox from the receiver, making sure that the wires don't get stuck.
      Ask FixBot
    8. G&G CM RK47 Airsoft Disassembly: step 8, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 8, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 8, image 3 of 3
      • Using a 2.5mm hex driver, remove the three screws that hold the stock to the receiver.
      • Pull the stock away from the receiver to remove it.
      Ask FixBot
    9. G&G CM RK47 Airsoft Disassembly: step 9, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 9, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 9, image 3 of 3
      • Remove the safety from the right side of the gearbox.
      • Remove the selector gear screw with a 2mm hex driver as shown.
      • Remove the selector gear assembly.
      Ask FixBot
    10. G&G CM RK47 Airsoft Disassembly: step 10, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 10, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 10, image 3 of 3
      • Lift the tabs on the small black cap behind the trigger, and then remove the cap.
      • Pull the wires out from under the tabs on the spring plate that runs along the top of the gearbox.
      • Carefully remove the spring plate by tapping it gently with a plastic hammer until it slides off the front of the gearbox.
      Ask FixBot
    11. G&G CM RK47 Airsoft Disassembly: step 11, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 11, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 11, image 3 of 3
      • Remove the four remaining gearbox screws with a 2mm hex driver.
      • Hold down the cylinder with your thumb while prying the gearbox apart from the top.
      • As you remove the right half of the gearbox, be sure to hold down the cylinder, piston, and spring assembly so that they do not pop out under tension.
      • Also keep a close eye out for any gear shims that may dislodge themselves as you are taking the gearbox apart.
      Ask FixBot
    12. G&G CM RK47 Airsoft Disassembly: step 12, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 12, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 12, image 3 of 3
      • Slowly lift the spring guide out of the gearbox along with the piston spring.
      • Remove the entire piston and cylinder assembly with the tappet plate, tappet plate spring, and air nozzle.
      • Remove the trigger assembly and lift up the wire harness, unhooking the trigger plunger spring in the process.
      Ask FixBot
    13. G&G CM RK47 Airsoft Disassembly: step 13, image 1 of 3 G&G CM RK47 Airsoft Disassembly: step 13, image 2 of 3 G&G CM RK47 Airsoft Disassembly: step 13, image 3 of 3
      • Pull the trigger plunger out of the wire harness.
      • Remove the three gears and the anti-reversal latch. Be careful not to misplace any of the shims or bushings, or the anti-reversal latch spring.
      Ask FixBot
    14. G&G CM RK47 Airsoft Disassembly: step 14, image 1 of 1
      • The RK47 is now fully disassembled.
      Ask FixBot
4 other people completed this guide.
101 Tech USA
4,197 Reputation
17 Guides authored
1 Guide Comment
That is really cool, and where can you buy this!
Ultimate Gamer - Reply Share
Past 24 Hours: 11
Past 7 Days: 46
Past 30 Days: 149
All Time: 8,398
