Fusion5 5.5 Gen II Midframe Replacement
    1. Fusion5 5.5 Gen II Midframe Replacement, Back Cover: step 1, image 1 of 2 Fusion5 5.5 Gen II Midframe Replacement, Back Cover: step 1, image 2 of 2
      • Hold the device with the screen facing away from you and the back of the device facing you.
      • Locate the groove at the bottom corner of the device.
      • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
      Ask FixBot
    1. Fusion5 5.5 Gen II Midframe Replacement, Midframe: step 2, image 1 of 2 Fusion5 5.5 Gen II Midframe Replacement, Midframe: step 2, image 2 of 2
      • Remove thirteen 3mm Phillips #00 screws from the midframe.
      • Remove the single 5mm Phillips #0 screw below the camera.
      Ask FixBot
    2. Fusion5 5.5 Gen II Midframe Replacement: step 3, image 1 of 2 Fusion5 5.5 Gen II Midframe Replacement: step 3, image 2 of 2
      • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
      • Be careful not to damage the cables inside the device when you pry the midframe off.
      Ask FixBot
1 Guide Comment
Hi Hwajin,
Thanks for your guides to the Fusion5. Do you happen to have a full User Manual. The quick start guide is useless.
Regards,
Richard
richardsailor1936@gmail.com - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 719
