Fusion5 5.5 Gen II Front & Rear Camera Replacement
    1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: step 1, image 1 of 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: step 1, image 2 of 2
      • Hold the device with the screen facing away from you and the back of the device facing you.
      • Locate the groove at the bottom corner of the device.
      • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
      Ask FixBot
    1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: step 2, image 1 of 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: step 2, image 2 of 2
      • Remove thirteen 3mm Phillips #00 screws from the midframe.
      • Remove the single 5mm Phillips #0 screw below the camera.
      Ask FixBot
    2. Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 3, image 1 of 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 3, image 2 of 2
      • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
      • Be careful not to damage the cables inside the device when you pry the midframe off.
      Ask FixBot
    1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Front & Rear Camera: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, flip the brown tab securing the ribbon cable.
      • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
      Ask FixBot
    2. Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 5, image 1 of 1
      • Using the tweezers, grab the ribbon cable and pull it out from its connector.
      • Then pull the front camera component out of its socket on the motherboard.
      Ask FixBot
    3. Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 6, image 1 of 1
      • Using tweezers, grasp the ribbon cable's metal tab and gently lift it to disconnect it from its connector on the motherboard.
      • Make sure to only lift by the metal tab and not the connector socket due to its susceptibility to break off.
      Ask FixBot
    4. Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 7, image 1 of 2 Fusion5 5.5 Gen II Front & Rear Camera Replacement: step 7, image 2 of 2
      • You may now grab and lift the rear-facing camera out of its socket on the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 669
