Furnace Humidifier Evaporator Pad Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
71
All Time:
1,139
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Furnace humidifiers are built in almost every household and their function is to help add moisture to the air to keep homes warm especially during the winter. If your furnace humidifier is not working optimally and producing enough warmth, this guide is helpful as there are times when you won’t be able to use an old evaporator pad optimally. Eventually, all the dust and particles can cause mold to grow on the evaporator pad. So, to find a solution to this, one would need to buy a new evaporator pad and replace the old one.
    1. Furnace Humidifier Evaporator Pad Replacement, Furnace Humidifier Evaporator Pad: step 1, image 1 of 1
      • Turn off the humidifier. (Set the humidistat to 0% humidity)
      Ask FixBot
    2. Furnace Humidifier Evaporator Pad Replacement: step 2, image 1 of 2 Furnace Humidifier Evaporator Pad Replacement: step 2, image 2 of 2
      • Remove the nuts and clips holding the top cover of the cabinet assembly to the bottom cabinet housing.
      Ask FixBot
    3. Furnace Humidifier Evaporator Pad Replacement: step 3, image 1 of 1
      • Remove the side clips or fasteners.
      Ask FixBot
    4. Furnace Humidifier Evaporator Pad Replacement: step 4, image 1 of 1
      • Use an adjustable wrench to loosen the nut which holds the water distributor tube and swing the tube out of its secured place.
      Ask FixBot
    5. Furnace Humidifier Evaporator Pad Replacement: step 5, image 1 of 1
      • Remove the top of the bottom cabinet housing and take out the evaporator pad.
      Ask FixBot
    6. Furnace Humidifier Evaporator Pad Replacement: step 6, image 1 of 2 Furnace Humidifier Evaporator Pad Replacement: step 6, image 2 of 2
      • Place the new evaporator pad inside the clean bottom cabinet.
      • The sides should guide it into the correct position.
      Ask FixBot
    7. Furnace Humidifier Evaporator Pad Replacement: step 7, image 1 of 1
      • Replace the clips, nuts, and bolts removed in steps 2 through 4.
      Ask FixBot
    8. Furnace Humidifier Evaporator Pad Replacement: step 8, image 1 of 1
      • Turn on the humidifier.
      Ask FixBot
Enjoy your warm air! Your repair is complete!
Zia Ahmed
190 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 71
All Time: 1,139
