Furbo Dog Camera USB Power Jack Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
96
All Time:
2,628
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Furbo Dog Camera does not turn on, or turns off and on without you doing it, the issue could lie deeper than replacing the cable. Your Furbo Dog Camera could have a faulty USB Power Jack that needs to be replaced.
In order to test this out, one should try a different USB cord and a different outlet before coming to the conclusion that there is an issue with the USB Power Jack inside. If your Furbo Dog Camera still does not work after changing the cable and the plug, it is safe to assume that there is an issue on the inside with the USB Power Jack.
There are eight steps to replace the USB Power Jack. All of the tools needed are available online and can be found at some large retail stores.
Tools
    1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: step 1, image 1 of 2 Furbo Dog Camera USB Power Jack Replacement, Back Cover: step 1, image 2 of 2
      • Remove the lid from the top of your Furbo Dog Camera.
      Ask FixBot
    2. Furbo Dog Camera USB Power Jack Replacement: step 2, image 1 of 3 Furbo Dog Camera USB Power Jack Replacement: step 2, image 2 of 3 Furbo Dog Camera USB Power Jack Replacement: step 2, image 3 of 3
      • Rotate your Furbo so that the bottom faces you.
      • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
      Ask FixBot
    3. Furbo Dog Camera USB Power Jack Replacement: step 3, image 1 of 3 Furbo Dog Camera USB Power Jack Replacement: step 3, image 2 of 3 Furbo Dog Camera USB Power Jack Replacement: step 3, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
      • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
      Ask FixBot
    4. Furbo Dog Camera USB Power Jack Replacement: step 4, image 1 of 3 Furbo Dog Camera USB Power Jack Replacement: step 4, image 2 of 3 Furbo Dog Camera USB Power Jack Replacement: step 4, image 3 of 3
      • Rotate your Furbo so that the side is facing towards you.
      • Use an opening tool to separate the two plastic coverings.
      Ask FixBot
    5. Furbo Dog Camera USB Power Jack Replacement: step 5, image 1 of 2 Furbo Dog Camera USB Power Jack Replacement: step 5, image 2 of 2
      • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
      Ask FixBot
    1. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: step 6, image 1 of 2 Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
      Ask FixBot
    2. Furbo Dog Camera USB Power Jack Replacement: step 7, image 1 of 2 Furbo Dog Camera USB Power Jack Replacement: step 7, image 2 of 2
      • Once you have removed the screws, gently pull the bundled cable connector free from the motherboard.
      Ask FixBot
    3. Furbo Dog Camera USB Power Jack Replacement: step 8, image 1 of 3 Furbo Dog Camera USB Power Jack Replacement: step 8, image 2 of 3 Furbo Dog Camera USB Power Jack Replacement: step 8, image 3 of 3
      • The USB power jack PCB can now be removed from your Furbo and replaced.
      Ask FixBot
Finish Line
1 Guide Comment
Where can you find a replacement
Brandon Alves - Reply Share
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 96
All Time: 2,628
