Furbo Dog Camera Treat Guide Chamber Replacement
  1. Furbo Dog Camera Treat Guide Chamber Replacement, Back Cover: step 1, image 1 of 2 Furbo Dog Camera Treat Guide Chamber Replacement, Back Cover: step 1, image 2 of 2
    • Remove the lid from the top of your Furbo Dog Camera.
    Ask FixBot
  2. Furbo Dog Camera Treat Guide Chamber Replacement: step 2, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 2, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 2, image 3 of 3
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
    Ask FixBot
  3. Furbo Dog Camera Treat Guide Chamber Replacement: step 3, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 3, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 3, image 3 of 3
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
    Ask FixBot
  4. Furbo Dog Camera Treat Guide Chamber Replacement: step 4, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 4, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 4, image 3 of 3
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
    Ask FixBot
  5. Furbo Dog Camera Treat Guide Chamber Replacement: step 5, image 1 of 2 Furbo Dog Camera Treat Guide Chamber Replacement: step 5, image 2 of 2
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
    Ask FixBot
  6. Furbo Dog Camera Treat Guide Chamber Replacement, Treat Guide Chamber: step 6, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement, Treat Guide Chamber: step 6, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement, Treat Guide Chamber: step 6, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the two small 3 mm black screws on either side of the plastic hinge.
    • After removing the two screws, carefully pull off the plastic hinge.
    Ask FixBot
  7. Furbo Dog Camera Treat Guide Chamber Replacement: step 7, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 7, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 7, image 3 of 3
    • Locate each end of the treat chamber door where the white plastic hook is latched behind the metal rod, and carefully unlatch the entire white plastic piece from the metal rod on both sides.
    Ask FixBot
  8. Furbo Dog Camera Treat Guide Chamber Replacement: step 8, image 1 of 2 Furbo Dog Camera Treat Guide Chamber Replacement: step 8, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws above the treat dispensing door.
    Ask FixBot
  9. Furbo Dog Camera Treat Guide Chamber Replacement: step 9, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 9, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 9, image 3 of 3
    • Lift up the treat dispensing door, and use a Phillips #000 screwdriver to remove the two 5 mm screws at the bottom of the dispensing hole.
    Ask FixBot
  10. Furbo Dog Camera Treat Guide Chamber Replacement: step 10, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 10, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 10, image 3 of 3
    • Carefully pull off the treat dispensing chamber with your hands and set it aside.
    • the treat dispensing chamber is the curved white plastic tube below the treat dispensing door.
    Ask FixBot
  11. Furbo Dog Camera Treat Guide Chamber Replacement: step 11, image 1 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 11, image 2 of 3 Furbo Dog Camera Treat Guide Chamber Replacement: step 11, image 3 of 3
    • Lift the treat chamber door, and carefully pull the treat guide chamber free.
    • This is the circular plastic piece that rests behind the treat dispensing door.
    Ask FixBot
  12. Furbo Dog Camera Treat Guide Chamber Replacement: step 12, image 1 of 2 Furbo Dog Camera Treat Guide Chamber Replacement: step 12, image 2 of 2
    • Now that both your treat guide chamber and treat dispensing chamber have been removed, you can stick your finger into the launching mechanism to dislodge any jammed treats.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 1,905
