Up to 20% off select tools
Furbo Dog Camera Back Cover Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
106
All Time:
2,556
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the rear housing and begin disassembly of your Furbo Dog Camera (Model:Furbo2). Removing the outer housing allows you to access the inside of your Furbo and fix and replace any parts if necessary. Sometimes separation of the plastic components may be difficult, so be careful not to break your Furbo.
    1. Furbo Dog Camera Back Cover Replacement, Back Cover: step 1, image 1 of 2 Furbo Dog Camera Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Remove the lid from the top of your Furbo Dog Camera.
      Ask FixBot
    2. Furbo Dog Camera Back Cover Replacement: step 2, image 1 of 3 Furbo Dog Camera Back Cover Replacement: step 2, image 2 of 3 Furbo Dog Camera Back Cover Replacement: step 2, image 3 of 3
      • Rotate your Furbo so that the bottom faces you.
      • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
      Ask FixBot
    3. Furbo Dog Camera Back Cover Replacement: step 3, image 1 of 3 Furbo Dog Camera Back Cover Replacement: step 3, image 2 of 3 Furbo Dog Camera Back Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
      • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
      Ask FixBot
    4. Furbo Dog Camera Back Cover Replacement: step 4, image 1 of 3 Furbo Dog Camera Back Cover Replacement: step 4, image 2 of 3 Furbo Dog Camera Back Cover Replacement: step 4, image 3 of 3
      • Rotate your Furbo so that the side is facing towards you.
      • Use an opening tool to separate the two plastic coverings.
      Ask FixBot
    5. Furbo Dog Camera Back Cover Replacement: step 5, image 1 of 2 Furbo Dog Camera Back Cover Replacement: step 5, image 2 of 2
      • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
      Ask FixBot
Author
with
Sarah Teague
265 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 106
All Time: 2,556
