Fujtsu Lifebook Model A6110 Disk Drive Replacement
  1. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: step 1, image 1 of 2 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Battery: step 1, image 2 of 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
    Ask FixBot
  2. Fujtsu Lifebook Model A6110 Disk Drive Replacement: step 2, image 1 of 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
    Ask FixBot
  3. Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: step 3, image 1 of 3 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: step 3, image 2 of 3 Fujtsu Lifebook Model A6110 Disk Drive Replacement, Disk Drive: step 3, image 3 of 3
    • The disk drive will be located on the side of the computer, on the top-left corner
    • Using a Phillips #1 screwdriver, remove the two 6 mm screws which are located above the disk drive. Remove the screws by turning your screwdriver counter-clockwise.
    Ask FixBot
  4. Fujtsu Lifebook Model A6110 Disk Drive Replacement: step 4, image 1 of 2 Fujtsu Lifebook Model A6110 Disk Drive Replacement: step 4, image 2 of 2
    • Insert the metal spudger in the gap between the disk drive and the laptop's body itself, as seen in the picture.
    • Push the spudger down, so that it is behind the drive.
    • Gently pull the disk drive out from the laptop until it unlatches.
    Ask FixBot
  5. Fujtsu Lifebook Model A6110 Disk Drive Replacement: step 5, image 1 of 1
    • Once the disk-drive has been unlatched from its slot, pull it gently from the laptop case.
    Ask FixBot
Cody Moniz
422 Reputation
4 Guides authored
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 813
