Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: step 1, image 1 of 2 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: step 1, image 2 of 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
    Ask FixBot
  2. Fujtsu Lifebook Model A6110 Battery Replacement: step 2, image 1 of 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
    Ask FixBot
Alvin Thamrin
153 Reputation
1 Guide authored
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 28
All Time: 924
