Fujitsu M2011 Hard Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
62
All Time:
726
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The tools you will need to replace the hard drive will be a Phillips screw driver. This repair may be required if your computer is running slow, or you have received an error for hard drive corruption.
Tools
    1. Fujitsu M2011 Hard Drive Replacement, Battery: step 1, image 1 of 2 Fujitsu M2011 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Slide switch #1 (shown) to the left.
      Ask FixBot
    2. Fujitsu M2011 Hard Drive Replacement: step 2, image 1 of 2 Fujitsu M2011 Hard Drive Replacement: step 2, image 2 of 2
      • Slide switch #2 (shown) to the right and hold.
      Ask FixBot
    3. Fujitsu M2011 Hard Drive Replacement: step 3, image 1 of 1
      • Pull the battery straight back out.
      Ask FixBot
    1. Fujitsu M2011 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Fujitsu M2011 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Remove the two 3 mm PH0 screws holding hard drive in place.
      Ask FixBot
    2. Fujitsu M2011 Hard Drive Replacement: step 5, image 1 of 1
      • Unfold the black tab attached to hard drive.
      Ask FixBot
    3. Fujitsu M2011 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the hard drive by pulling the black tab.
      Ask FixBot
Brandon Stowers
97 Reputation
1 Guide authored
IUPUI, Team S2-G5, Baechle Fall 2018 Member of IUPUI, Team S2-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 62
All Time: 726
