Fujitsu Lifebook T1010 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
53
All Time:
800
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The goal of this guide is to show how to replace RAM in the Fujitsu Lifebook T1010.
Tools
    1. Fujitsu Lifebook T1010 RAM  Replacement, RAM: step 1, image 1 of 1
      • Remove the two Phillips #0 screws from the cover.
      Ask FixBot
    2. Fujitsu Lifebook T1010 RAM  Replacement: step 2, image 1 of 1
      • Remove the cover.
      Ask FixBot
    3. Fujitsu Lifebook T1010 RAM  Replacement: step 3, image 1 of 1
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • When released, the RAM module will pop up at a slight angle.
      • Lift the RAM module to an angle of about 30 degrees and slide it out.
      Ask FixBot
Chitara Smith
620 Reputation
3 Guides authored
Gateway, Team S1-G3, Johnson Spring 2018 Member of Gateway, Team S1-G3, Johnson Spring 2018
GCC-JOHNSON-S18S1G3
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 53
All Time: 800
