Up to 20% off select tools
Fujitsu Lifebook S6120 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
77
All Time:
1,933
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the keyboard is not responding or inputs incorrectly then your keyboard may need to be replaced, this guide will show you how to remove the keyboard from the Fujitsu Lifebook S6120.
    1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: step 1, image 3 of 3
      • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
      • Push the two tabs in towards the laptop.
      • Lift the battery up and out from the frame of the laptop.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: step 2, image 1 of 2 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: step 2, image 2 of 2
      • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Keyboard Replacement: step 3, image 1 of 1
      • Lift the hinge cover.
      • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
      Ask FixBot
    3. Fujitsu Lifebook S6120 Keyboard Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to disconnect the ribbon cable from the motherboard.
      Ask FixBot
    4. Fujitsu Lifebook S6120 Keyboard Replacement: step 5, image 1 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 5, image 2 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 5, image 3 of 3
      • With the tweezers detach hinge cover cables from the motherboard.
      • Remove hinge cover.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: step 6, image 1 of 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: step 6, image 2 of 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: step 6, image 3 of 3
      • Lift keyboard enough to show the ribbon cable.
      • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Keyboard Replacement: step 7, image 1 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 7, image 2 of 3 Fujitsu Lifebook S6120 Keyboard Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to release the ribbon cable from the motherboard.
      Ask FixBot
Author
with
Jessi Gallant
944 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 77
All Time: 1,933
