Up to 20% off select tools
Fujitsu Lifebook S6120 Fan Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
73
All Time:
1,412
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the laptop tends to overheat then the laptop fan may need to be replaced, this guide will show you how to remove the fan from the Fujitsu Lifebook S6120.
    1. Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 3 of 3
      • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
      • Push the two tabs in towards the laptop.
      • Lift the battery up and out from the frame of the laptop.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: step 2, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: step 2, image 2 of 2
      • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Fan Replacement: step 3, image 1 of 1
      • Lift the hinge cover.
      • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
      Ask FixBot
    3. Fujitsu Lifebook S6120 Fan Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to disconnect the ribbon cable from the motherboard.
      Ask FixBot
    4. Fujitsu Lifebook S6120 Fan Replacement: step 5, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 5, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 5, image 3 of 3
      • With the tweezers detach hinge cover cables from the motherboard.
      • Remove hinge cover.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 3 of 3
      • Lift keyboard enough to show the ribbon cable.
      • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Fan Replacement: step 7, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 7, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to release the ribbon cable from the motherboard.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 3 of 3
      • Push the secure clips outward.
      • The Adapter should pop up.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Fan Replacement: step 9, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 9, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 9, image 3 of 3
      Buy
      • Use tweezers to remove the wires from the Adapter.
      Ask FixBot
    3. Fujitsu Lifebook S6120 Fan Replacement: step 10, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 10, image 2 of 2
      • Take out the Adapter and carefully pull the wires out from the metal casing.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Fan Replacement, Motherboard: step 11, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement, Motherboard: step 11, image 2 of 2
      • Use a Philips head #0 to remove the 5mm screws.
      • Use a Philips head #00 to remove the 4mm screws.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Fan Replacement: step 12, image 1 of 1
      • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
      Ask FixBot
    3. Fujitsu Lifebook S6120 Fan Replacement: step 13, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 13, image 2 of 2
      Buy
      • Remove the ribbon from the motherboard with a pair of tweezers.
      Ask FixBot
    4. Fujitsu Lifebook S6120 Fan Replacement: step 14, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 14, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 14, image 3 of 3
      • Use a 5mm nut driver to unscrew the nuts.
      Ask FixBot
    5. Fujitsu Lifebook S6120 Fan Replacement: step 15, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 15, image 2 of 2
      • Pull the ribbon tab up and off the motherboard.
      Ask FixBot
    6. Fujitsu Lifebook S6120 Fan Replacement: step 16, image 1 of 1
      • Remove the metal plate covering the motherboard.
      Ask FixBot
    7. Fujitsu Lifebook S6120 Fan Replacement: step 17, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 17, image 2 of 2
      • Remove the 3.5mm screws with a Philips head #0.
      • Remove the metal bracket and other pieces that rely on it for structure.
      Ask FixBot
    8. Fujitsu Lifebook S6120 Fan Replacement: step 18, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 18, image 2 of 2
      • Pinch your fingers around the base of the connector and pull it out.
      Ask FixBot
    9. Fujitsu Lifebook S6120 Fan Replacement: step 19, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 19, image 2 of 2
      • Lift the motherboard off the plastic base.
      Ask FixBot
    1. Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 3 of 3
      • Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
      Ask FixBot
    2. Fujitsu Lifebook S6120 Fan Replacement: step 21, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 21, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 21, image 3 of 3
      Buy
      • Using tweezers detach the cable from the motherboard.
      Ask FixBot
    3. Fujitsu Lifebook S6120 Fan Replacement: step 22, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 22, image 2 of 2
      • The fan can now be removed from the motherboard.
      Ask FixBot
Author
with
Jessi Gallant
944 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 73
All Time: 1,412
