Fujitsu Lifebook E556 HDD/SSD Replacement
  1. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing Battery: step 1, image 1 of 1
    • Remove battery:
    • 1. Pull down and hold that little tab.
    • 2. Move left that slider.
    • 3. Pull up to remove battery from laptop.
    Ask FixBot
  2. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing HDD/SSD Cover: step 2, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • To remove HDD/SSD cover, you need to:
    • 1. Remove screw holding cover.
    • 2. Pull up the cover by notch visible right next to screw hole. If difficult to pull by finger, use a plastic card or guitar pick.
    Ask FixBot
  3. Fujitsu Lifebook E556 HDD/SSD Replacement, Removing HDD/SSD: step 3, image 1 of 1
    • To remove HDD/SSD, you need to pull disk outwards of connector.
    • When disconnected, pull up the disk away from bay.
    • Important! If you wanna place a new disk, make sure it is SLIM format. It is standard for 2,5" SSDs, so nothing to worry about.
    • 2,5" HDDs were made in 2 different thicknesses: standard (9mm) and slim (7mm)
    • Mine laptop is lacking two rubber bands, that are holding disk. They're not a necessity, cover has some thick rubber on it too, so disk should stay in place.
    Ask FixBot
Michał Kurda
1,027 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 73
All Time: 1,088
