Fujitsu Lifebook E546 RAM Modules Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
87
All Time:
815
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hello!
In this guide I will show you how to replace RAM module/stick in Fujitsu Lifebook laptop, model E546. It is very easy. However, if you're doing this for the first time, simply take your time. I don't take any responsibility for any damage done by yourself!
I recommend to keep your screw and parts organized - it helps with reassembling and lowers risk of missing screws!
Tools
    1. Fujitsu Lifebook E546 RAM Modules Replacement, Removing battery: step 1, image 1 of 1
      • Before doing something, always remove the battery!
      • First, gently pull down and hold that little tab down (1) to unlock the second tab.
      • Then move left the second tab (2). Both tabs should be secured in OPEN position.
      • Now you can pull battery out by simply lifting it by that notch (3).
      Ask FixBot
    2. Fujitsu Lifebook E546 RAM Modules Replacement, Removing RAM modules cover: step 2, image 1 of 1
      • To remove RAM modules cover, just undo one screw (highlited in photo). Then lift cover by notch next to the screw hole.
      Ask FixBot
    3. Fujitsu Lifebook E546 RAM Modules Replacement: step 3, image 1 of 1
      • Now you can see you RAM modules bay. RAM stick is held by two clips - one at each side.
      • Gently pull the tabs outwards. Released RAM stick should pop-up upwards to certain angle.
      • Gently remove RAM stick. To insert a new stick, push it into slot at an angle. Make sure it is evenly seated, then push it down until clips will secure it.
      Ask FixBot
Michał Kurda
1,054 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 87
All Time: 815
