Fujitsu Lifebook A6110 RAM Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
90
All Time:
1,531
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
The Fujtsu Lifebook Model a6110 RAM is what's going to determine your laptop’s speed. Once it begins to slow down or crash without warning, this signals that you will need to remove and replace your random access memory (RAM). Whether you are replacing or upgrading your system's memory, this easy-to-use guide demonstrates the process in six steps. Due to the electrical components, here's a link for tips and demonstrations on how to protect yourself prior to starting our steps in the guide.
Tools
    1. Fujitsu Lifebook A6110 RAM Replacement, Battery: step 1, image 1 of 2 Fujitsu Lifebook A6110 RAM Replacement, Battery: step 1, image 2 of 2
      • The computer should be fully turned off and disconnected from the power source.
      • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
      • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
      Ask FixBot
    2. Fujitsu Lifebook A6110 RAM Replacement: step 2, image 1 of 1
      • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
      Ask FixBot
    1. Fujitsu Lifebook A6110 RAM Replacement, RAM: step 3, image 1 of 2 Fujitsu Lifebook A6110 RAM Replacement, RAM: step 3, image 2 of 2
      • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
      • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
      Ask FixBot
    2. Fujitsu Lifebook A6110 RAM Replacement: step 4, image 1 of 3 Fujitsu Lifebook A6110 RAM Replacement: step 4, image 2 of 3 Fujitsu Lifebook A6110 RAM Replacement: step 4, image 3 of 3
      • Slide the cover towards the screw, and then lift the cover upwards.
      Ask FixBot
    3. Fujitsu Lifebook A6110 RAM Replacement: step 5, image 1 of 2 Fujitsu Lifebook A6110 RAM Replacement: step 5, image 2 of 2
      • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
      • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
      • If done correctly, the RAM card will eject at a 45 degree angle.
      Ask FixBot
    4. Fujitsu Lifebook A6110 RAM Replacement: step 6, image 1 of 1
      • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
      • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
      • If you choose to replace the other RAM card, repeat the process in Step 5.
      Ask FixBot
Cody Moniz
422 Reputation
4 Guides authored
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 90
All Time: 1,531
