Fujitsu LifeBook U810 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
83
All Time:
1,145
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the battery for the Fujitsu Lifebook U810 is a simple process that does not require a toolkit of any kind. This guide helps repair a short battery life for the device and can improve the overall lifespan. You can find a new battery online by searching the model number and corresponding part for the U810 model.
    1. Fujitsu LifeBook U810 Battery Replacement, Battery: step 1, image 1 of 3 Fujitsu LifeBook U810 Battery Replacement, Battery: step 1, image 2 of 3 Fujitsu LifeBook U810 Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the Lifebook so it's underside is showing and you see a small latch with the lock symbol on the right side.
      Ask FixBot
    2. Fujitsu LifeBook U810 Battery Replacement: step 2, image 1 of 1
      • Push the latch to the right to release the battery.
      Ask FixBot
    3. Fujitsu LifeBook U810 Battery Replacement: step 3, image 1 of 3 Fujitsu LifeBook U810 Battery Replacement: step 3, image 2 of 3 Fujitsu LifeBook U810 Battery Replacement: step 3, image 3 of 3
      • Hold the latch in the unlocked position and with your other hand pull the battery straight out from the back of the device.
      Ask FixBot
Emmy Hughes
147 Reputation
1 Guide authored
UC Davis, Team S4-G7, Lore Fall 2018 Member of UC Davis, Team S4-G7, Lore Fall 2018
UCD-LORE-F18S4G7
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 83
All Time: 1,145
