Fujitsu LifeBook N3510 Hinge Cover Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
93
All Time:
4,089
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The hinge cover has the computer power button, wireless switch, and volume toggle.
Tools
    1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Battery: step 1, image 1 of 1
      • Locate the two clips on the bottom of the computer that support the battery.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Hinge Cover Replacement: step 2, image 1 of 1
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
      Ask FixBot
    1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: step 3, image 1 of 3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: step 3, image 2 of 3 Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: step 3, image 3 of 3
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Hinge Cover Replacement: step 4, image 1 of 1
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
      Ask FixBot
    3. Fujitsu LifeBook N3510 Hinge Cover Replacement: step 5, image 1 of 3 Fujitsu LifeBook N3510 Hinge Cover Replacement: step 5, image 2 of 3 Fujitsu LifeBook N3510 Hinge Cover Replacement: step 5, image 3 of 3
      • Use a spudger to partially lift the hinge cover.
      Ask FixBot
    4. Fujitsu LifeBook N3510 Hinge Cover Replacement: step 6, image 1 of 2 Fujitsu LifeBook N3510 Hinge Cover Replacement: step 6, image 2 of 2
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
      Ask FixBot
    5. Fujitsu LifeBook N3510 Hinge Cover Replacement: step 7, image 1 of 2 Fujitsu LifeBook N3510 Hinge Cover Replacement: step 7, image 2 of 2
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
      Ask FixBot
Neil Daniels
1,411 Reputation
11 Guides authored
Cal Poly, Team 5-18, Amido Winter 2011 Member of Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 93
All Time: 4,089
