Fujitsu LifeBook N3510 Fan Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
111
All Time:
4,614
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Fujitsu LifeBook N3510 Fan Replacement, Battery: step 1, image 1 of 1
      • Locate the two clips on the bottom of the computer that support the battery.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Fan Replacement: step 2, image 1 of 1
      • Using your fingers, push the clips inward and then upward.
      • Lift the battery out of the computer.
      Ask FixBot
    1. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: step 3, image 1 of 3 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: step 3, image 2 of 3 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: step 3, image 3 of 3
      • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Fan Replacement: step 4, image 1 of 1
      • Lay the computer flat on a stable surface with the monitor pointing away from you.
      Ask FixBot
    3. Fujitsu LifeBook N3510 Fan Replacement: step 5, image 1 of 3 Fujitsu LifeBook N3510 Fan Replacement: step 5, image 2 of 3 Fujitsu LifeBook N3510 Fan Replacement: step 5, image 3 of 3
      • Use a spudger to partially lift the hinge cover.
      Ask FixBot
    4. Fujitsu LifeBook N3510 Fan Replacement: step 6, image 1 of 2 Fujitsu LifeBook N3510 Fan Replacement: step 6, image 2 of 2
      • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
      • Lift the hinge cover enough to expose the ribbon cable.
      Ask FixBot
    5. Fujitsu LifeBook N3510 Fan Replacement: step 7, image 1 of 2 Fujitsu LifeBook N3510 Fan Replacement: step 7, image 2 of 2
      • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
      Ask FixBot
    1. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: step 8, image 1 of 3 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: step 8, image 2 of 3 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: step 8, image 3 of 3
      • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
      • Lift the keyboard enough to expose the ribbon cable.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Fan Replacement: step 9, image 1 of 2 Fujitsu LifeBook N3510 Fan Replacement: step 9, image 2 of 2
      • Use a spudger to release the ribbon cable from the motherboard.
      Ask FixBot
    3. Fujitsu LifeBook N3510 Fan Replacement: step 10, image 1 of 2 Fujitsu LifeBook N3510 Fan Replacement: step 10, image 2 of 2
      • After the ribbon has been detached, carefully remove the keyboard.
      Ask FixBot
    1. Fujitsu LifeBook N3510 Fan Replacement, Metal Motherboard Cover: step 11, image 1 of 1
      • Remove the following screws, all labeled "3."
      • Two 8.63mm screws.
      • One 7.65mm screw.
      • One 5.74mm screw.
      • Remove the following screw, labeled "15."
      • One 17.81mm screw.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Fan Replacement: step 12, image 1 of 3 Fujitsu LifeBook N3510 Fan Replacement: step 12, image 2 of 3 Fujitsu LifeBook N3510 Fan Replacement: step 12, image 3 of 3
      • Lift the cover with fingers and remove.
      Ask FixBot
    1. Fujitsu LifeBook N3510 Fan Replacement, Fan: step 13, image 1 of 3 Fujitsu LifeBook N3510 Fan Replacement, Fan: step 13, image 2 of 3 Fujitsu LifeBook N3510 Fan Replacement, Fan: step 13, image 3 of 3
      • Detach fan cable from motherboard.
      Ask FixBot
    2. Fujitsu LifeBook N3510 Fan Replacement: step 14, image 1 of 1
      • Remove labeled screws.
      Ask FixBot
    3. Fujitsu LifeBook N3510 Fan Replacement: step 15, image 1 of 2 Fujitsu LifeBook N3510 Fan Replacement: step 15, image 2 of 2
      • Remove fan.
      Ask FixBot
Neil Daniels
1,411 Reputation
11 Guides authored
Cal Poly, Team 5-18, Amido Winter 2011 Member of Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 111
All Time: 4,614
