Shop the Holiday Gift Guide
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
107
All Time:
6,623
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
In this guide, you will learn how to safely replace the hard drive of a Fujitsu LIFEBOOK P7010D laptop.
Typically, laptop hard drives should be replaced every 3-5 years. If you keep track of your hard drive’s age, you can preemptively replace it before it fails. Hard drive failure can lead to slow functioning, data corruption, and overheating.
Tools
    1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down on a table.
      Ask FixBot
    2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 2, image 1 of 1
      • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
      • Using two fingers, press both tabs down at once until they are fully depressed.
      Ask FixBot
    3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 3, image 1 of 1
      • While holding the tabs down, slowly pivot the battery up.
      • The battery is now free and safe to pull out.
      Ask FixBot
    1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: step 4, image 1 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: step 4, image 2 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: step 4, image 3 of 3
      • Push the tab down as far as possible using your finger or opening tool to unlock the disc drive.
      • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
      Ask FixBot
    1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: step 5, image 1 of 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: step 5, image 2 of 2
      • On the bottom of the laptop, find the two bottom-plate screw holes near the disc drive. Parallel to them is a 2.4mm screw (second photo).
      • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew it.
      Ask FixBot
    2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 6, image 1 of 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 6, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Flip the laptop over and open it facing you.
      • The cover is connected to the inner computer with an aluminum strip, so be careful lifting it.
      • Use a plastic opening tool to lift the bottom black cover on both sides.
      • For the proceeding steps, put on an anti-static wrist strap to protect the delicate circuitry inside the computer. To learn how to use the anti-static wrist strap, click here.
      Ask FixBot
    3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 7, image 1 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 7, image 2 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 7, image 3 of 3
      • The hard drive is connected with a strip, so be careful when lifting it out.
      • Once the black cover is lifted, gently flip it and set it on the keyboard.
      • Locate the disc drive on the right side, as pictured.
      • Using two fingers and the clear plastic handles on the top, gently lift it out. Place it on the side of the laptop.
      Ask FixBot
    4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 8, image 1 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 8, image 2 of 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: step 8, image 3 of 3
      • Flip the hard drive on its side.
      • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
      • Hold the hard drive and insert a plastic opening tool, preferably a wider one, in between the black pin holder and the hard drive.
      • Gently wiggle the black pin holder back and forth, on each side, until it comes off.
      Ask FixBot
3 other people completed this guide.
Author
with
Nicholas Ross
207 Reputation
7 Guides authored
Cal Poly, Team 10-31, Amido Winter 2012 Member of Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Members
84 Guides authored
1 Guide Comment
hai sir..please help me..how to replacement hdd lifebook PH770/5AN ? can you answer to my email antogantengnian@gmail.com..thanks a lot
anto adhitya - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 107
All Time: 6,623
