Fujitsu Esprimo Mobile V6555 Keyboard Replacement
    1. Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing battery: step 1, image 1 of 2 Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing battery: step 1, image 2 of 2
      • 1. Turn your notebook over.
      • 2. For safety reasons, remove your battery. Turn switch on right inwards. Do the same with the one on the left. Hold it, then remove battery pack.
      Ask FixBot
    2. Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing plastic elements: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • 3. Turn your laptop back and open it wide.
      • 4. Use plastic card or guitar pick to release plastic from latches. Be gentle, it's only plastic.
      Ask FixBot
    3. Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing keyboard: step 3, image 1 of 3 Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing keyboard: step 3, image 2 of 3 Fujitsu Esprimo Mobile V6555 Keyboard Replacement, Removing keyboard: step 3, image 3 of 3
      • 5. Keyboard is held in place by two plastic latches. You can gentle push it out.
      • 6. When you pull out the keyboard, you have to disconnect it from motherboard. There is a lever-action ZIF (Zero Insertion Force) connector. Simply open black part upwards.
      • 7. With connector opened, gently pull out the ribbon cable.
      Ask FixBot
Michał Kurda
1,027 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 895
