Fujifilm XP20 Rear Case Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
82
All Time:
1,410
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide if the rear case is cracked or broken and needs to be replaced. Replacing the rear case requires removing of screws which may be difficult if they are stripped.
Tools
    1. Fujifilm XP20 Rear Case Replacement, Rear Case: step 1, image 1 of 3 Fujifilm XP20 Rear Case Replacement, Rear Case: step 1, image 2 of 3 Fujifilm XP20 Rear Case Replacement, Rear Case: step 1, image 3 of 3
      • Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
      • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws on the bottom of the front face.
      Ask FixBot
    2. Fujifilm XP20 Rear Case Replacement: step 2, image 1 of 3 Fujifilm XP20 Rear Case Replacement: step 2, image 2 of 3 Fujifilm XP20 Rear Case Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the 3.0 mm screws on the bottom of the camera closer to the back.
      • Using a Phillips #00 screwdriver remove the two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
      Ask FixBot
    3. Fujifilm XP20 Rear Case Replacement: step 3, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws.
      Ask FixBot
    4. Fujifilm XP20 Rear Case Replacement: step 4, image 1 of 3 Fujifilm XP20 Rear Case Replacement: step 4, image 2 of 3 Fujifilm XP20 Rear Case Replacement: step 4, image 3 of 3
      • Using a 1.5mm Hex screwdriver, remove the 3.0 mm hex screw on top edge of silver panel.
      • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
      • Once both screws are removed the silver side casing will slide off.
      Ask FixBot
    5. Fujifilm XP20 Rear Case Replacement: step 5, image 1 of 3 Fujifilm XP20 Rear Case Replacement: step 5, image 2 of 3 Fujifilm XP20 Rear Case Replacement: step 5, image 3 of 3
      • Unlatch the four clasps located on each side of the camera by hand.
      • The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm XP20 Battery Replacement for instructions.
      Ask FixBot
    6. Fujifilm XP20 Rear Case Replacement: step 6, image 1 of 3 Fujifilm XP20 Rear Case Replacement: step 6, image 2 of 3 Fujifilm XP20 Rear Case Replacement: step 6, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the seven 3.0 mm screws.
      • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
      • The rear panel is now free from the camera.
      Ask FixBot
Stephen Harden
243 Reputation
2 Guides authored
IUPUI, Team 1-1, Wilson Fall 2016 Member of IUPUI, Team 1-1, Wilson Fall 2016
IUPUI-WILSON-F16S1G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 82
All Time: 1,410
