Fujifilm X30 EVF Replacement/Teardown
Views: 3.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
122
All Time:
3,316
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Remove EVF from Fujifilm X30, and get a teardown of EVF lenses
Tools
    1. Fujifilm X30  EVF Replacement/Teardown, Remove EVF: step 1, image 1 of 3 Fujifilm X30  EVF Replacement/Teardown, Remove EVF: step 1, image 2 of 3 Fujifilm X30  EVF Replacement/Teardown, Remove EVF: step 1, image 3 of 3
      • Follow disassembly instructions from disassembly guide through step 17
      • unscrew 2 philips screws.
      • Slide the EVF to remove it. Becareful "play" button will come out too.
      Ask FixBot
    2. Fujifilm X30  EVF Replacement/Teardown, Separate lens block and LCD: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Adhesive sealing tape can be just worked out with tweezers to unstick it without removing it.
      Ask FixBot
    3. Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: step 3, image 1 of 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: step 3, image 2 of 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: step 3, image 3 of 3
      Magnetic Project Mat
      $19.95
      Buy
      • disassembly plastic cover
      • unscrew plastic wheel.
      • Becareful not to loose the little metal ball
      • Working on a magnetic mat can be handful
      • when re-assembling:
      • put the first plastic wheel on place
      • Drop the ball in the hole, and put the spring over it
      • Then screw the second plastic wheel over it
      Ask FixBot
    4. Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: step 4, image 1 of 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: step 4, image 2 of 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: step 4, image 3 of 3
      • To remove lens block, you have to push the 2 metal rods from one side to the other. The rods have one end thinner than the other
      • Now you can remove every lens in order to clean them from dust or humidity
      • When re-assembling, there's only one way to get them back in, so keep track of lenses order and direction when removing each one of them. Or wou'll have to try many times to comlete the puzzle.
      Ask FixBot
arnau COSTA BEAL
125 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 122
All Time: 3,316
