Fujifilm Instax Minion Camera Shell Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
78
All Time:
2,903
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This replacement is fairly straight forward. The only tool you will need is a #00 Phillips screwdriver and/or an extra long #00 Phillips screwdriver. Optionally, you could use a nylon spudger to help pry open the camera shell.
Tools
    1. Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: step 1, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: step 1, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement, Camera Shell: step 1, image 3 of 3
      • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
      Ask FixBot
    2. Fujifilm Instax Minion Camera Shell Replacement: step 2, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 2, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 2, image 3 of 3
      • Use a spudger to remove the film slot guard on the top of the camera.
      • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
      Ask FixBot
    3. Fujifilm Instax Minion Camera Shell Replacement: step 3, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 3, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 3, image 3 of 3
      • Press the release tab on the back of the camera to open the film compartment.
      • Remove the film cartridge within this compartment.
      Ask FixBot
    4. Fujifilm Instax Minion Camera Shell Replacement: step 4, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 4, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 4, image 3 of 3
      • Press the battery cover in and down to remove it.
      • Remove any batteries within.
      Ask FixBot
    5. Fujifilm Instax Minion Camera Shell Replacement: step 5, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 5, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 5, image 3 of 3
      • Use a plastic opening tool to help pry the front and back shells apart.
      • With the camera facing down, remove only the back shell.
      Ask FixBot
    6. Fujifilm Instax Minion Camera Shell Replacement: step 6, image 1 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 6, image 2 of 3 Fujifilm Instax Minion Camera Shell Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully peel the front side of the shell away.
      • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
      • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
      Ask FixBot
Jonnah Lee
473 Reputation
3 Guides authored
Cal Poly, Team S18-G6, Livingston Spring 2018 Member of Cal Poly, Team S18-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 78
All Time: 2,903
