Up to 20% off select tools
Fujifilm Instax Mini Eight Camera Shell Replacement
Views: 72K
View statistics:
Past 24 Hours:
12
Past 7 Days:
67
Past 30 Days:
328
All Time:
72,352
Comments: 22
3 comments on steps, 19 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The camera shell is the plastic casing that makes up the outside of the Fujifilm Instax Mini 8; which is meant to hide wires, protect the film, and hold the main components of this camera together in a compact manner. A damaged shell will compromise the integrity of the device and may cause other parts of the camera to malfunction.
    1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 3 of 3
      • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
      • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
      Ask FixBot
    2. Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 3 of 3
      • Press the tab down in order to unlatch the film compartment cover.
      • Remove the film from the compartment (if any is present)
      • Remove the compartment cover completely.
      • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
      Ask FixBot
    3. Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 3 of 3
      • Use the plastic opening tools and spudger to safely remove the front shell casing.
      Ask FixBot
    4. Fujifilm Instax Mini Eight Camera Shell Replacement: step 4, image 1 of 2 Fujifilm Instax Mini Eight Camera Shell Replacement: step 4, image 2 of 2
      • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
      • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
      • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
      Ask FixBot
14 other people completed this guide.
Author
with
Bo W
1,052 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
60 Guides authored
19 Guide Comments
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - Reply Share
but where near the exit? i cannot find it
Emily Birkler - Reply Share
It's at the top of the camera where you get picture.
xxx - Reply Share
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - Reply Share
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - Reply Share
Past 24 Hours: 12
Past 7 Days: 67
Past 30 Days: 328
All Time: 72,352
