Fujifilm Instax Mini 9 Flash Capacitor Replacement
  1. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Untie Wrist Strap: step 1, image 1 of 1
    • Untie the wrist strap by loosening the small black end of it, and pulling the large part out of the loop it makes which holds it in place.
    Ask FixBot
  2. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove the Batteries: step 2, image 1 of 2 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove the Batteries: step 2, image 2 of 2
    • Turn the camera on its side and take off the battery cover by pulling down while putting pressure onto the cover.
    • Remove both AA batteries.
    Ask FixBot
  3. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove the Film Cartridge: step 3, image 1 of 2 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove the Film Cartridge: step 3, image 2 of 2
    • Turn the camera to its back side and push down on the clip at the top of the film cover and remove film.
    Ask FixBot
  4. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Shell Screws: step 4, image 1 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Shell Screws: step 4, image 2 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Shell Screws: step 4, image 3 of 3
    • Remove the six shell screws highlighted using a Philips #00 screwdriver.
    Ask FixBot
  5. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Printer Shroud: step 5, image 1 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Printer Shroud: step 5, image 2 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Printer Shroud: step 5, image 3 of 3
    • Remove the shroud for the film printer. Carefully pry around the edge of the shroud until the part comes loose.
    Ask FixBot
  6. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Pry Off the Lens Shroud: step 6, image 1 of 2 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Pry Off the Lens Shroud: step 6, image 2 of 2
    • Carefully pry around the lens shroud in a circular motion in order to remove it.
    Ask FixBot
  7. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Unhook Lens Spring: step 7, image 1 of 2 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Unhook Lens Spring: step 7, image 2 of 2
    • Unhook the spring attached to the lens.
    Ask FixBot
  8. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Separate Camera Shell: step 8, image 1 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Separate Camera Shell: step 8, image 2 of 3 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Separate Camera Shell: step 8, image 3 of 3
    • Gently pry along the shell seam while tracing the seam along all sides of the camera. Take the front shell off the camera once the shell is released.
    Ask FixBot
  9. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Take Button Off: step 9, image 1 of 1
    • Take the button that controls the shutter off of the camera.
    Ask FixBot
  10. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Battery Slot: step 10, image 1 of 2 Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Battery Slot: step 10, image 2 of 2
    • Remove the battery slot by unscrewing the two highlighted screws. Once loose, remove the piece to reveal the capacitor.
    • Note: These two screws are smaller than the case screws removed earlier.
    Ask FixBot
  11. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Remove Capacitor: step 11, image 1 of 1
    • Heat the soldering iron up to 600°F and firmly hold it onto the soldered contacts.
    • Replace the flash capacitor by de-soldering the highlighted contacts.
    • Use a soldering wick or a vacuum pump to absorb the melted solder and remove capacitor once the wires are separated from the contacts.
    • Note: The capacitor is rated for 320V and has a capacitance of 300µF
    Ask FixBot
  12. Fujifilm Instax Mini 9 Flash Capacitor Replacement, Resolder the Wires: step 12, image 1 of 1
    • Solder the two white wires back into place.
    Ask FixBot
3 other people completed this guide.
g124um
283 Reputation
1 Guide authored
1 Guide Comment
Doesn’t want to take pictures of flash or take the role
Joseline - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 182
All Time: 2,273
