Fujifilm Instax Mini 8 Lens Unit Replacement
Views: 76K
View statistics:
Past 24 Hours:
8
Past 7 Days:
46
Past 30 Days:
247
All Time:
76,328
Comments: 15
2 comments on steps, 13 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Before attempting repairs, please take note of certain risks of receiving shock from the camera's flash capacitor. Also make sure to ground yourself before operating on or near the camera's motherboard or you might discharge static to crucial components.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: step 1, image 1 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: step 1, image 2 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement, Lens Unit: step 1, image 3 of 3
      • First, push in the lens and remove the two AA batteries.
      Ask FixBot
    2. Fujifilm Instax Mini 8 Lens Unit Replacement: step 2, image 1 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 2, image 2 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 2, image 3 of 3
      • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera.
      • Once all screws are removed, gently pry open the front casing carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
      Ask FixBot
    3. Fujifilm Instax Mini 8 Lens Unit Replacement: step 3, image 1 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 3, image 2 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 3, image 3 of 3
      • Locate the four screws on the lens unit by the corners and remove them to loosen the lens casing from the main frame. Make sure to keep hold of the unit screws to use for the next step.
      Ask FixBot
    4. Fujifilm Instax Mini 8 Lens Unit Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Lens Unit Replacement: step 4, image 3 of 3
      • Remove the lens unit from the main camera frame.
      • Obtain the replacement part to perform the replacement operation.
      Ask FixBot
9 other people completed this guide.
Bo W
1,052 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
60 Guides authored
13 Guide Comments
the lens covers on my lens broke (the small black pieces that cover the lenses) and i am unable to put back on, will this affect my camera and pictures because of the ex poser?
marisabellares - Reply Share
When I dropped my instax mini 8, none of the lense pieces broke, they just fell apart, I just need to puzzle them back together. Can you make a tutorial to put the yellow and black parts in the lense back together?
Julia Tyler - Reply Share
My daughter dropped her camera and the round, hard plastic part that goes over the lens fell out along with a black piece that has four prongs. There is also a spring attached at a section that would look like 4-5 o'clock if looking at the camera head on. I am not sure where the other end of spring attaches to. Please help
Mike Rutledge - Reply Share
I too am having the same problem as the people in the posts above. Is there a solution somewhere? Thanks
Toby Gilling - Reply Share
I followed this tutorial but when I initally took the case apart a small rectangular piece fell out and I'm not sure where it should go. The piece has a hole which is set to one side, and a slight groove and arch. I can't see the piece on any of the tutorials. Can anyone help? Thanks
Nicola Jaye - Reply Share
Past 24 Hours: 8
Past 7 Days: 46
Past 30 Days: 247
All Time: 76,328
