Fujifilm Instax Mini 8 Flash Unit Replacement
Views: 38K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
141
All Time:
37,927
Comments: 13
3 comments on steps, 10 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The main purpose of this page is to assure the owner of a Fujifilm Instax Mini 8 is capable of disassembling the camera in order to remove and replace the flash unit, if there was to ever be any problems with the flash. Before attempting repairs, please take note of certain risks of receiving shock from the camera's flash capacitor. Also make sure to ground yourself before operating on the camera's motherboard or you might discharge static to crucial components.
Tools
    1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: step 1, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: step 1, image 2 of 2
      • You start off with the camera.
      Ask FixBot
    2. Fujifilm Instax Mini 8 Flash Unit Replacement: step 2, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 2, image 2 of 2
      • Open up the back and remove the film cartridge.
      Ask FixBot
    3. Fujifilm Instax Mini 8 Flash Unit Replacement: step 3, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 3, image 2 of 2
      • Remove the two Phillips #00 screws from the bottom of the camera.
      • Remove the two screws on the side of the camera.
      • Additionally, there are two screws in the battery compartment which also need to be removed.
      Ask FixBot
    4. Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 3 of 3
      • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
      • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
      Ask FixBot
    5. Fujifilm Instax Mini 8 Flash Unit Replacement: step 5, image 1 of 1
      • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
      Ask FixBot
    6. Fujifilm Instax Mini 8 Flash Unit Replacement: step 6, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 6, image 2 of 2
      • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
      Ask FixBot
    7. Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 1 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 2 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 3 of 3
      • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
      Ask FixBot
5 other people completed this guide.
Bo W
1,052 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
60 Guides authored
10 Guide Comments
Where can I purchase the flash unit?
Casey Sanders - Reply Share
Hi, did you ever find out where to replace the flash light unit?
Rachel Street - Reply Share
Why is all the camera lights flashing red and doesn't work?
medgabby - Reply Share
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - Reply Share
Where can I find the flash unit to purchase??
Maria - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 141
All Time: 37,927
