Fujifilm Instax Mini 8 Capacitor Replacement
Views: 29K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
179
All Time:
29,328
Comments: 3
3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 35 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Before attempting repairs, please take note of certain risks of receiving shock from the camera's flash capacitor. Also make sure to ground yourself before operating on the camera's motherboard or you might discharge static to crucial components.
Tools
    1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 3 of 3
      • First, push in the lens and remove the two AA batteries.
      Ask FixBot
    2. Fujifilm Instax Mini 8 Capacitor Replacement: step 2, image 1 of 2 Fujifilm Instax Mini 8 Capacitor Replacement: step 2, image 2 of 2
      • Open the rear compartment and remove the film cartridge.
      Ask FixBot
    3. Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 3 of 3
      • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
      Ask FixBot
    4. Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 3 of 3
      • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
      Ask FixBot
    5. Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 3 of 3
      • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
      Ask FixBot
    6. Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 3 of 3
      • Carefully pry out the capacitor with a spudger or plastic opening tools.
      Ask FixBot
    7. Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 3 of 3
      • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
      Ask FixBot
6 other people completed this guide.
Bo W
1,052 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
60 Guides authored
3 Guide Comments
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Reply Share
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Reply Share
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 179
All Time: 29,328
