Fujifilm Instax Mini 70 Shell Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
108
All Time:
1,700
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide will show you how to properly remove the shell of the Fujifilm Instax Mini 70. No special skills required.
Tools
    1. Fujifilm Instax Mini 70 Shell Replacement, Shell: step 1, image 1 of 2 Fujifilm Instax Mini 70 Shell Replacement, Shell: step 1, image 2 of 2
      • Look at the bottom of the camera and find the four 6 mm Phillips #0 screws and remove them.
      Ask FixBot
    2. Fujifilm Instax Mini 70 Shell Replacement: step 2, image 1 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 2, image 2 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 2, image 3 of 3
      • Use a jimmy to separate the front and back shells. Then, use your hands to gently pull the back shell away from the front until it fully detaches.
      Ask FixBot
    3. Fujifilm Instax Mini 70 Shell Replacement: step 3, image 1 of 2 Fujifilm Instax Mini 70 Shell Replacement: step 3, image 2 of 2
      • At the top of the camera, locate the 8 mm Phillips #0 screw and remove it.
      Ask FixBot
    4. Fujifilm Instax Mini 70 Shell Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 4, image 3 of 3
      • Use your hands to gently pull the front shell off of the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 108
All Time: 1,700
