Fujifilm FinePix Z5 Optical Lens Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
85
All Time:
1,556
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The optical lens is frequently reported as 'not working' or broken. This guide will take you through the steps of removing the malfunctioning lens and installing a new one.
Tools
    1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: step 1, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: step 1, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: step 1, image 3 of 3
      • Remove the two screws from the right side of the camera and the two screws from the left side.
      • Use a small #00 Phillips flat head screwdriver.
      • Keep all the screws in a container and the two different types separate.
      Ask FixBot
    2. Fujifilm FinePix Z5 Optical Lens Replacement: step 2, image 1 of 1
      • Remove the three screws from the bottom of the camera.
      • Use a three-prong screwdriver for two of the three screws; keep these screws separate.
      Ask FixBot
    3. Fujifilm FinePix Z5 Optical Lens Replacement: step 3, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 3, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 3, image 3 of 3
      • Remove the back by carefully flipping it open to the right side.
      • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
      Ask FixBot
    4. Fujifilm FinePix Z5 Optical Lens Replacement: step 4, image 1 of 2 Fujifilm FinePix Z5 Optical Lens Replacement: step 4, image 2 of 2
      • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
      • There is an orange ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
      Ask FixBot
    5. Fujifilm FinePix Z5 Optical Lens Replacement: step 5, image 1 of 2 Fujifilm FinePix Z5 Optical Lens Replacement: step 5, image 2 of 2
      • Using a plastic opening tool to flip open the black lever to release the ribbon cable.
      • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
      Ask FixBot
    6. Fujifilm FinePix Z5 Optical Lens Replacement: step 6, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 6, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 6, image 3 of 3
      • Remove the two screws that are holding the silver paneling on.
      • There is a gold foil which will tear upon removal of the silver paneling, this is normal.
      • Remove the screw anchoring the motherboard on the right.
      Ask FixBot
    7. Fujifilm FinePix Z5 Optical Lens Replacement: step 7, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 7, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 7, image 3 of 3
      • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
      • Detach the gold ribbon cable on the top middle of the camera as well.
      Ask FixBot
    8. Fujifilm FinePix Z5 Optical Lens Replacement: step 8, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 8, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 8, image 3 of 3
      • Hold wires on the left with an index finger, to keep them out of the way.
      • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
      • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
      Ask FixBot
    9. Fujifilm FinePix Z5 Optical Lens Replacement: step 9, image 1 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 9, image 2 of 3 Fujifilm FinePix Z5 Optical Lens Replacement: step 9, image 3 of 3
      • Lift the lens off of the camera base (there is nothing anchoring it down).
      Ask FixBot
Inga Direktorchuk
72 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 1,556
