Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
    Ask FixBot
  2. Fujifilm FinePix Z1 Battery Replacement: step 2, image 1 of 1
    • Turn the camera to the bottom and find the battery access door on the left side.
    Ask FixBot
  3. Fujifilm FinePix Z1 Battery Replacement: step 3, image 1 of 2 Fujifilm FinePix Z1 Battery Replacement: step 3, image 2 of 2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
    Ask FixBot
  4. Fujifilm FinePix Z1 Battery Replacement: step 4, image 1 of 1
    • Push the yellow tab to eject the battery.
    Ask FixBot
  5. Fujifilm FinePix Z1 Battery Replacement: step 5, image 1 of 1
    • Remove the battery and replace with a new one.
    Ask FixBot
Carra
533 Reputation
4 Guides authored
Baylor, Team S2-G4, Johnson Spring 2018 Member of Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 43
All Time: 1,243
