Fujifilm FinePix XP80 LCD Screen Replacement
  1. Fujifilm FinePix XP80 LCD Screen Replacement, Battery: step 1, image 1 of 3 Fujifilm FinePix XP80 LCD Screen Replacement, Battery: step 1, image 2 of 3 Fujifilm FinePix XP80 LCD Screen Replacement, Battery: step 1, image 3 of 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
    Ask FixBot
  2. Fujifilm FinePix XP80 LCD Screen Replacement: step 2, image 1 of 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
    Ask FixBot
  3. Fujifilm FinePix XP80 LCD Screen Replacement, Exterior Case: step 3, image 1 of 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
    Ask FixBot
  4. Fujifilm FinePix XP80 LCD Screen Replacement: step 4, image 1 of 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
    Ask FixBot
  5. Fujifilm FinePix XP80 LCD Screen Replacement: step 5, image 1 of 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
    Ask FixBot
  6. Fujifilm FinePix XP80 LCD Screen Replacement: step 6, image 1 of 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
    Ask FixBot
  7. Fujifilm FinePix XP80 LCD Screen Replacement: step 7, image 1 of 1
    • Gently pry the side area of the case apart.
    Ask FixBot
  8. Fujifilm FinePix XP80 LCD Screen Replacement: step 8, image 1 of 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
    Ask FixBot
  9. Fujifilm FinePix XP80 LCD Screen Replacement: step 9, image 1 of 2 Fujifilm FinePix XP80 LCD Screen Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
    Ask FixBot
  10. Fujifilm FinePix XP80 LCD Screen Replacement, Interior Case: step 10, image 1 of 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
    Ask FixBot
  11. Fujifilm FinePix XP80 LCD Screen Replacement: step 11, image 1 of 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
    Ask FixBot
  12. Fujifilm FinePix XP80 LCD Screen Replacement: step 12, image 1 of 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
    Ask FixBot
  13. Fujifilm FinePix XP80 LCD Screen Replacement: step 13, image 1 of 3 Fujifilm FinePix XP80 LCD Screen Replacement: step 13, image 2 of 3 Fujifilm FinePix XP80 LCD Screen Replacement: step 13, image 3 of 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
    Ask FixBot
  14. Fujifilm FinePix XP80 LCD Screen Replacement: step 14, image 1 of 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
    Ask FixBot
  15. Fujifilm FinePix XP80 LCD Screen Replacement, LCD Screen: step 15, image 1 of 1
    • Once you expose the inside of the camera, use the PH000 Phillips head bit and remove the four screws as shown.
    • Carefully remove the tape binding the screen to the camera.
    Ask FixBot
  16. Fujifilm FinePix XP80 LCD Screen Replacement: step 16, image 1 of 1
    • Gently pry the LCD screen from the case, using a plastic opening tool.
    Ask FixBot
  17. Fujifilm FinePix XP80 LCD Screen Replacement: step 17, image 1 of 1
    • Unclip the LCD data line from the mother board, using the plastic opening tool.
    Ask FixBot
Daniela Pesci
194 Reputation
2 Guides authored
USF Tampa, Team 1-3, Cagle Fall 2016 Member of USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 32
All Time: 819
