Fujifilm FinePix S8200 Selector Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,744
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Selector is an important part of the camera because it controls the LCD screen. To replace it, follow the below steps.
Tools
    1. Fujifilm FinePix S8200 Selector  Replacement, Batteries: step 1, image 1 of 1
      • Turn the camera upside down so you can access the battery chamber.
      • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
      Ask FixBot
    2. Fujifilm FinePix S8200 Selector  Replacement: step 2, image 1 of 1
      • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
      Ask FixBot
    3. Fujifilm FinePix S8200 Selector  Replacement: step 3, image 1 of 1
      • With the battery chamber open, remove the old batteries.
      • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
      Ask FixBot
    1. Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: step 4, image 1 of 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: step 4, image 2 of 3 Fujifilm FinePix S8200 Selector  Replacement, Rear Housing Cover: step 4, image 3 of 3
      • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
      Ask FixBot
    2. Fujifilm FinePix S8200 Selector  Replacement: step 5, image 1 of 3 Fujifilm FinePix S8200 Selector  Replacement: step 5, image 2 of 3 Fujifilm FinePix S8200 Selector  Replacement: step 5, image 3 of 3
      • Carefully pry away the rear housing cover with the plastic opening tool.
      Ask FixBot
    3. Fujifilm FinePix S8200 Selector  Replacement: step 6, image 1 of 1
      • Remove the rear housing cover by carefully pulling it away from the camera.
      Ask FixBot
    1. Fujifilm FinePix S8200 Selector  Replacement, Removing Selection Button: step 7, image 1 of 1
      • To Replace the Selection button, carefully pull the button until the button has been fully detached.
      Ask FixBot
Ugent Dailey
119 Reputation
1 Guide authored
1 Guide Comment
preciso dessa peça.. aonde consigo encontrar para comprar? email: smchous@hotmail.com
smchous - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,744
