Fujifilm FinePix S4800 Battery Replacement
    1. Fujifilm FinePix S4800 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure that the camera is powered off before continuing.
      • Rotate the camera so that the label on the base of the camera is facing up.
      • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
      Ask FixBot
    2. Fujifilm FinePix S4800 Battery Replacement: step 2, image 1 of 3 Fujifilm FinePix S4800 Battery Replacement: step 2, image 2 of 3 Fujifilm FinePix S4800 Battery Replacement: step 2, image 3 of 3
      • Remove all four batteries and set them aside.
      • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
      Ask FixBot
Stephen Calabrese
611 Reputation
3 Guides authored
USF Tampa, Team S19-G4, Hoffman Spring 2017 Member of USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Members
42 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 69
All Time: 4,827
